humming noise come from belt?
Old May 27, 2014 | 11:20 AM
octoher12's Avatar
Exclamation humming noise come from belt?
Can someone help me identify this belt! I don't know too much about cars and just need some help/advice..
I started my car this morning and i herd a little humming noise. I got out the car popped open the hood and herd this humming noise coming from this belt!
Sorry for the pic i had to do a screen shot!
what is this belt called and do?
Old May 27, 2014 | 12:16 PM
ErickUa5's Avatar
Mr.Helpful Diagram
That the Power Steering Pump and it helps you move the steering wheel while the car is not moving.
You may have the O-ring failure, bearing or belt. Its best if you post a video of the noise to better help.
Old May 27, 2014 | 01:10 PM
octoher12's Avatar
I will work on making a video when i go on my lunch break!
This humming sound only happens on a cold start, once i drive off it goes away and acts perfectly normal. I also have a check engine light that illuminated today, i will post the code when i go one break. Hopefully its nothing serious!
Old May 27, 2014 | 03:27 PM
octoher12's Avatar
Well i couldnt get the belt to make noise aging :/
Its just there on a cold start.
But i do have the check engine code which is P0401.
I dont know if its related to the belt or not! If anyone had any experience with this code
can you please help,
thanks
Old May 27, 2014 | 04:52 PM
01tl4tl's Avatar
our diy list has a code sheet, or use outside search engine for acura code Pyadayada
Old May 27, 2014 | 06:08 PM
3.2TLc's Avatar
P0401 is normally associated with the EGR system. When was the last time that the TB intake and EGR passageways were cleaned ? Been awhile....try that first !!!
Old May 27, 2014 | 06:27 PM
octoher12's Avatar
I bought the car from a dealership. I really don't know if it was cleaned or not. Thank you i will start there first, what would be the price range on this type of work?
Old May 28, 2014 | 07:44 AM
3.2TLc's Avatar
If ya are mechanically inclined.....read the "DIY" sticky for cleaning procedure tips. The cost of stuff needed is less than $20. If ya take it to a shop, figure on at least an hour or two of labor at their going rate plus the cleaning materials. Maybe $100 or so, IDK ?
Old May 28, 2014 | 08:53 AM
ErickUa5's Avatar
Mr.Helpful Diagram
Heres the perfect video for that code,
Old May 28, 2014 | 09:26 AM
octoher12's Avatar
Hell yea! Thanks man.
Well the noise from the belt was making noise agin on a cold start. I have a video on my phone but i dont know how to post it on here :/
Old May 28, 2014 | 10:00 AM
ErickUa5's Avatar
Mr.Helpful Diagram
No problem.
Try to get the video off your phone onto a computer and you can upload it to Youtube then just copy the link from Youtube and paste on here.
Old May 28, 2014 | 12:15 PM
octoher12's Avatar
Ok so this is the video of my car making that noise.
Seems like everyday on a COLD START, it seems to get louder and louder.
https://www.youtube.com/watch?v=6I_v...ature=youtu.be
Old May 28, 2014 | 05:30 PM
ErickUa5's Avatar
Mr.Helpful Diagram
That thing is screaming O-ring, you need to pull the pump out to change it out with a new one.
http://www.ebay.com/itm/Genuine-OEM-Honda-Power-Steering-Pump-O-Ring-/400649855281?pt=Motors_Car_Truck_Parts_Accessories&hash=item5d4897a131&vxp=mtr
You can also get this part at your local Acura or Honda dealer
Old May 28, 2014 | 05:38 PM
octoher12's Avatar
yay! more problems lol
Im going to do the EGR valve myself most likely. Am i ok driving with the o-ring acting like this? im a daily highway driver.
What would be a "guesstimate" price on this job.
Old May 30, 2014 | 09:22 PM
octoher12's Avatar
I didnt want to start a new thread about the same problem so ill just double post.
I bought the o ring for my tl. But its black? I bought it at the honda dealer, they told me the black one is for the top of the pump and the orange one is for the one thats close to the engine.
Im confused because i seen a video on youtube and the guy was changing the o ring thats on top of the pump itself and said if the ring is black change it to orange.
So the question is - Does the color of the oring really matter?
The oring i bought. Part #: 91370-sv4-000
Thanks in advance
Old May 30, 2014 | 11:11 PM
ErickUa5's Avatar
Mr.Helpful Diagram
Thanks in advance
Not that I know of, I believe that was part of the recall for the 3rd Gen TL. Although its similar the pump needs to be taken out.
You need the one closer to the engine which is: 91345-RDA-A01, The one you bought is the for the upper hose thats not the one but its a good idea to replace it while you're there.
Consider purchasing 1 bottle of power steering fluid to replace the fluid lost during the o-ring replacement.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
08KBP_VA
Oct 22, 2019 01:55 PM
SexyRL
4G TL Problems & Fixes
Aug 19, 2016 10:03 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
Boraxo
1/2G MDX (2001-2013)
Sep 29, 2015 04:35 PM
