help, rpm is not stable
Old Oct 27, 2006 | 07:18 AM
Blueyce28's Avatar
ok. the last time i turned on the car was wednesday morning to repark myself. other than that, it sat there all day yesterday.
this morning when i turned on the car to warm it, the idle was not stable. it kept jumping between 1000rpm - 2100 rpm. it does it quick too. like it'll rev up on it's own to 2100 rpm and then just drop to 1000rpm and does it again continuously. so i turn it off, let it sit for a few, turned it back on and same thing, even after it's been warmed up.
i can feel the idle just dropping when in motion. if i sit there on the brakes and let go it'll just jump to go( guess cuz of the higher idle). and when i start to stop. i can feel it the rpm dropping and kicking back in pushing me further then dropping again....
i went ahead and drove to work cuz i had to be there. it wasn't until i got there when the "Engine" light came on. 5 min later i turned it back on to show somebody, this time, only the engine light is on and the idle stopped doing it's thing, except, this time the idle keeps dropping and dropping, then it starts idling at almost 400-500 rpm.......
anything to help, thanks.
Old Oct 27, 2006 | 07:20 AM
Blueyce28's Avatar
guru fsttyms1, what do you think? i need ya on this one. thanks.
Old Oct 27, 2006 | 07:31 AM
fsttyms1's Avatar
Sounds like the IAC Valve
Old Oct 27, 2006 | 07:44 AM
Blueyce28's Avatar
is that expensive?
Old Oct 27, 2006 | 07:51 AM
Blueyce28's Avatar
or do you think a simple cleaning of the IAC would work?
or maybe just simply replace it?
i don't even know where it is...
Old Oct 27, 2006 | 02:55 PM
fsttyms1's Avatar
The iac is the part on the bottom of the TB. You can take it off and try to clean it and see if that helps. If not it will have to be replaced
Old Oct 27, 2006 | 03:10 PM
99BamaTL's Avatar
Mine does that every once in a while. I can take a hammer and tap on the throttle body and the problem will go away for a while. I'm assuming I'm getting some carbon build up on the IAC valve.
Old Oct 28, 2006 | 09:06 AM
fsttyms1's Avatar
Dont be hitting those parts with a hammer. You will cause more "Bamage" Try removing ans cleaning. If that doesnt work it needs replacing
DerrickW
Nov 15, 2015 05:52 PM
Houston
Oct 8, 2015 01:27 AM
wubly
4G TL Problems & Fixes
Oct 6, 2015 02:45 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
ROSSARONIE
Sep 22, 2015 11:46 AM
