Gas gauge issues........
Old Jun 7, 2006 | 08:55 AM
justinp's Avatar
Whenever i fill up my guage really never goes to full. It sits around 3/4 left, and it has only gone to full once since ive had the car and that as after it was turned off and turned back on. What is this problem?
Old Jun 7, 2006 | 09:11 AM
JAYCEE's Avatar
Possibly your fuel sending unit not really sure if that comes with the floater, that may also have a sensor that reads the level of fuel in your tank. Not 100% sure though, theres some troubleshooting to be done before determining that for sure.
Old Jun 7, 2006 | 10:23 AM
fsttyms1's Avatar
id say it may be the sending unit in the tank. Also do you stop filling as soon as the automatic shut off triggers or do you continue on a few times after?
Old Jun 7, 2006 | 10:29 AM
justinp's Avatar
I go a couple of clicks.
Old Jun 7, 2006 | 11:10 AM
SatinSilverTypS's Avatar
ChairmanMaoSaysRTFM
that's not good. my friend flooded the vapor recovery system in his 2004 accord doing that.
i always stop on the automatic stop in the pump handle and it always ends up a tick or two over full anyway.
worst case scenario: you need to change your float and sender, but the good news is that it's easy to do on the tl since the access panel is right in the trunk. i had to drop the tank on my girlfriends ford tempo to do hers several years ago and i swore after that that if i ever had to do it again i would sawzall an access in the trunk for myself.
SSTS
Old Jun 7, 2006 | 11:30 AM
justinp's Avatar
SSTS
what does a float and sender cost?
Old Jun 7, 2006 | 12:50 PM
fsttyms1's Avatar
SSTS
been doing that for 200k miles and not a problem. if i left it when it first shut off it wouldnt be full
Old Jun 7, 2006 | 01:36 PM
Rpappi's Avatar
DRINKING HAS A ME PROBLEM
same here i fill it up over the click also. no harm done.
Old Jun 7, 2006 | 03:37 PM
tim'sTLS's Avatar
true that guys.always include xtra clik or two or to nearest dollar or cents.
Old Jun 8, 2006 | 05:36 PM
JAYCEE's Avatar
After some research I found a bulletin that may apply
Bulletin # 99-036 Price on this part is around $120.00 and if you do it yourself thats not too bad of a cost. all depends on how picky you are. You might just want to live with an inaccurate fuel gauge
To correct your problem you will need to replace the fuel gauge sending unit.
Part # 17630-S0K-A51
You can get to it from the the trunk, I can fax you a copy of the bulletin.
Hit me up
Old Jun 12, 2006 | 11:19 PM
justinp's Avatar
Oh cool thanks, Eventually i will have to do this but for now its not a HUGE issue.
Old Jun 13, 2006 | 06:21 AM
ChairmanMaoSaysRTFM
well i used to do it also with all the other cars i've owned and never had a problem, but i don't do it now. perhaps our VRS is different from the accords, who knows. luckily my guage is always past full when it clicks off anyway ::shrugs::
justinp - sorry i didn't answer your question sooner. i wasn't around much over the weekend.
SSTS
Old Jun 15, 2006 | 11:20 AM
mdavisii's Avatar
B93P TL Owner
Had the exact same thing happen to me on my 99. $280 later I had a new sending unit installed. Almost three years now since the replacement and it still works like a charm.
Old Jun 15, 2006 | 02:00 PM
justinp's Avatar
Ok, Cool guys. I guess thats on my list of To-Do's now. Thanks for the help.
Old Jan 11, 2023 | 07:33 PM
RRK0818's Avatar
did you by chance tune your car using hondata? It so that's your issue.
CL-S progression 01
Jan 26, 2016 04:15 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
Skirmich
Oct 1, 2015 12:59 PM
San Yasin
Sep 29, 2015 10:52 AM
