funny starts
Old Feb 15, 2009 | 04:58 PM
rob-2's Avatar
funny starts
Occationally my car starts up and it almost struggles to come alive. It'll idle rough and be between 500-700 rpm. If I flick the gas it runs fine and idles 700rpm.
It might happen one in 20-30 starts. It normally happens when I've driven somewhere, 10+ miles, and turn the car off. Then when I started in 5-10 minutes later I get this.
129K
Fully serviced
Fresh Battery (6 months old)
Thoughts?
Old Feb 15, 2009 | 07:06 PM
newperson's Avatar
There's no Acura in
129K
Fully serviced
Thoughts?
Interesting, my car exhibits the same behavior every once in a while. The starter will turn the engine more than usual before the car comes up and when it does it idles very low and my lights may dim. Almost feels like it's gonna cut off, but everything eventually levels out.
rob-2, do you experience this: sometimes when the fan comes on (under the hood by radiator) the car jumps forward and lights dim for a split second? I've felt it might be electrical / battery-related but if you've only had your battery 6 months I'm starting to think alternator.
Old Feb 15, 2009 | 09:36 PM
bromat80's Avatar
Interesting, I encountered this the other day. Turned it off right away, turned it back on and it acted as if nothing happened.
Old Feb 16, 2009 | 09:50 PM
rob-2's Avatar
No, I dont experience that problem. My alternator was checked at the time of battery change and provides a strong charge.
Think it could fail quickly over the last 6 months?
I do A LOT of short trips now. 2-3 less than 2 mile hops.
Old Feb 16, 2009 | 10:29 PM
01tl4tl's Avatar
rob- those short trips are killers on the battery- it uses a big shot of amps to crank the starter, then you barely get the car warm (another possible issue) and the alternator doesnt get run long enough to recharge the battery fully
Stop by zone or similar store for a free batt alt starter draw test- check the cables too
Old Feb 17, 2009 | 01:16 AM
DC3328's Avatar
Your Garage
i get the same problem occasionally
Old Feb 17, 2009 | 09:37 AM
rob-2's Avatar
Hey Tom,
Does that explain this?
Rob
Old Feb 17, 2009 | 11:07 AM
01tl4tl's Avatar
not sure thats your entire issue but could contribute- take it in for a free test between rainstorms
Old Feb 17, 2009 | 11:08 AM
01tl4tl's Avatar
per acura book- if driven less than 10 mile trips-
once a week take it on the freeway for 30 minute cruise to dry out the moisture from the exhaust and ps fluid
(and probably charge the battery full-IMO)
Old Feb 17, 2009 | 12:48 PM
rob-2's Avatar
we do, sunday morning we drive about 20-25 miles. I'll get it checked in the coming weeks. Sometimes it just JUMPS to life an other times it acts up.
Powder Monkey
2G CL Problems & Fixes
Sep 9, 2018 12:55 AM
obert
Dec 14, 2015 11:36 PM
DNS91
Sep 29, 2015 10:11 AM
cak165
1G TSX Problems & Fixes
Sep 16, 2015 08:17 PM
jordanboi
Sep 5, 2015 01:33 AM
