Front window regulator DIY ???
Old Feb 23, 2011 | 12:14 AM
hermtm2's Avatar
Hello.
My brother's TL (2000) has a problem with his window on the driver's side. It doesn't move up and down even though we can still hear the motor noise. I guess that the window is simply out of the clip on the frame (regulator) inside.
Has anyone done this job? I am looking for DIY or at least a couple of pictures. The one I found on the web is too brief to have an idea.
Thanks.
Old Feb 25, 2011 | 09:47 AM
fsttyms1's Avatar
Its been done, but i havent seen a DIY or pictures for it.
Old Feb 25, 2011 | 10:16 AM
AlanW's Avatar
2006 NBP TL MT6/ 02TL-S
I'm betting part of regulator lift system is broken
Probably either the cable broke or the plastic cable retainer has broke. My rear window did this.
From what I researched on here and what I saw after taking the door panel off, is that there is no way to fix it, you have to buy the whole assembly and replace it. Cost vary depending on which window, but it's going to be at least around $150.
Old Feb 25, 2011 | 11:04 AM
01tl4tl's Avatar
see phone book ads - call glass places that offer `used auto glass` (often located next to junkyard)
they know what breaks and if they have the part or will need dealer item
happy to sell it to you, or do the work right for not too much cash compared to other shops
Old Feb 25, 2011 | 11:06 AM
01tl4tl's Avatar
a broken plastic roller thats not replaceable-- I can easily imagine being at fault--thats acura~
Old Feb 25, 2011 | 11:09 AM
40kalz's Avatar
this is a piece of cake to do done these plenty of times go on you tube they have plenty info there.
Old Oct 8, 2011 | 06:43 PM
OSO420's Avatar
5th Gear
This exact same thing happened to my car a few days ago. I finally took the door panel off today and noticed two pieces sitting in the door.
That plate where the cables meet and the white wheel under it. The cable is still in tact. Is this fixable? Is there a way to rethread the cable to the wheel and get that plate back on?
TLDude876
Dec 28, 2016 03:18 PM
snorf
Sep 17, 2015 10:04 PM
ahsm
Sep 9, 2015 08:35 AM
gqdabien
Sep 8, 2015 11:41 PM
08 NBP TL
Sep 8, 2015 08:49 PM
