Fog Light Mod MaDneSS!!!
Old Nov 22, 2006 | 06:41 PM
CJITTY's Avatar
Ackniculous One
Ok, so I was having the issue that some of us had with the fog light mod. When arming the car, the right headlight would flicker. I know I did the mod right, there are only two wires (3 and 4) that need to be spliced together. I did that over 2 years ago but always had that flicker issue.
So, I decided to undo the mod today. Now, my indicator light to tell me the fogs are on is no longer illuminating???? I know it was working before I un-did the mod.
Another strange thing. I bought and installed my Philips 6000K bulbs for my headlights about a month ago. I thought they were considerably less bright than the 4300K. So I put some new 4300K's back in after that. Today, I decided to put the 6000K's back in after I un-did the fog light mod as a little test. Now that removed the mod, my 6000K's seem much brighter!! Call me crazy, but I am very particular about stuff like this and I am 95% sure they are brighter.
Does anyone know if the mod in any way can affect power to the ballasts??
So now, I still need to figure out why my indicator light no longer comes on. The fog light emblem glows when I have dash lights on, just not the center green light???
Any thoughts are welcome!
Old Nov 23, 2006 | 09:26 AM
CJITTY's Avatar
Ackniculous One
does anyone have the part number for the fog light switch?? I'm still trying to figure out what happened...hoping someone had a thought.
Happy Thanksgiving all!!!
Old Nov 23, 2006 | 01:17 PM
acurabum's Avatar
There's a small tiny bulb inside the fog light switch and you might check it if blowwwww.....
I replace mine 2 month ago (TL-P 02 )
Old Nov 23, 2006 | 01:25 PM
S1CK TypeS's Avatar
B A N N E D
i have the flicker issue to so now i shut my HIDs off and jus leave the fogs on. as for the brightness i didnt really notice a brightness loss in my 4300k but thats jus me. and for the fog light switch i have no freakin clue, see if your highbeams are on
Old Nov 23, 2006 | 11:59 PM
CJITTY's Avatar
Ackniculous One
Yeah, I checked the high beams and everything. I had the mod in for two years or so. I knew something was strange with the flickering. I finally undid the mod because I was concerned that the flickering could cause a problem for my ballasts, especially the right headlight ballast. I usually did turn off the headlights, but I figured I would undo the mod for awhile.
I find it odd that the light would stop working as soon as I did un-did the mod. The only thing I can think of is the power in the wires blew it out or when I removed the switch to undo the mod, the vibration may have broke the light. I assume that light can be replaced somehow. Does anyone know?
Old Nov 24, 2006 | 10:01 AM
acurabum's Avatar
Remove the Fog Light switch and look at the back of it ...there is a round base bulb in plastic that you could remove with a small srewdriver ....
Oh yeah remember to buy one first.
Old Nov 24, 2006 | 07:02 PM
CJITTY's Avatar
Ackniculous One
Yeah, I went to Acura today to get a new bulb. They want..get this...$12 for the green bulb that is for the "on" indicator light and $2 for the off white color bulb that goes on the bottom of the switch to illuminate the fog lamp switch for the dash. Guess what, I just got the $2 bulb and put it in. I'm not paying $10 extra dollars just to have it green. It's sorta orange color now when the fogs are on, looks kind of cool. Since I have yellow fogs, it makes sense. It still seems to me that fog light mod is restricting power to my headlights. Can't tell for sure, but now that the mod is out, my headlights don't flicker and they seem brighter. I dunno..weird.
Old Nov 27, 2006 | 10:59 AM
acurabum's Avatar
You should remove the small green rubber from the burned bulb and put it on your new
white color bulb .... that green rubber make it lights green .........
Old Nov 12, 2012 | 10:38 AM
yankeedoyle's Avatar
3rd Gear
Are there any detailed instructions on how to access the fog lamp indicator bulb? Any help is greatly appreciated.
Old Nov 12, 2012 | 11:08 AM
fsttyms1's Avatar
A.) Carefully pry/pull out the switch and pull it out. Once out you will see the bulb socket.
or
B.) Remove lower dash knee pad and reach hand up and push switch out.
InFaMouSLink
Oct 27, 2015 06:51 PM
sockr1
Oct 1, 2015 01:31 AM
oyayjoe
Sep 12, 2015 04:40 PM
ellisd03tls
Sep 8, 2015 04:17 PM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
