Extra "clunk" after bumps and dips
Old Aug 11, 2011 | 03:59 PM
JRhodes88's Avatar
Need an OEM lip kit on my
I've had my Function & Forms for a little while now and they have always been extremely stiff and you usually hear every bump and dip like normal. But as of recently I have been noticing an extra "clunk" after the usual noise.
It happens more when I hip a bump with my front drivers side tire and I can almost feel it in the wheel too. I did a quick check of my upper ball joints (SPC Performance) and they seem to be solid as a rock still. Anything else I should check?
My dad told me I should check the Control Arms and he thinks it could also be bearings. What do you guys think? What methods should I try to diagnose the extra "clunk".
Thanks!
Old Aug 11, 2011 | 05:45 PM
swllen_cu's Avatar
control arms are hitting the strut tower
Old Aug 11, 2011 | 06:13 PM
JRhodes88's Avatar
Should I just replace the upper control arms then?
Old Aug 12, 2011 | 08:20 AM
JRhodes88's Avatar
Also, are there any good aftermarket control arms?
Old Aug 12, 2011 | 10:05 AM
01tl4tl's Avatar
no, it means something is not installed right--new arms wont change that!
do ck sway bar end links, control arm upper and lower bushings and anything else connected in that area
Look for shiny metal where parts are rubbing together
I had a cars sway bar be mounted slightly offset from correct- where in just the right conditions it hit the control arm--the giveaway? shiny metal in a small area!!
Have an alignment shop put in on the lift and inspect.. if you are not sure how to
Old Aug 12, 2011 | 11:05 AM
JRhodes88's Avatar
It's easy to check everything when you have a lift! lol
I might have to do that. I installed the coilovers a while ago and had it aligned. Do you think something might be just "giving out" and it's rubbing something somewhere? I'll look for this elusive shiny metal you speak of
Old Aug 12, 2011 | 04:43 PM
01tl4tl's Avatar
a set of ramps works too
Old Aug 14, 2011 | 03:32 PM
JRhodes88's Avatar
Ok, I checked for any signs of something rubbing and I couldn't really find anything. I didn't have time to take the tires off, but here are some pictures of what everything looked like. I did notice the lower ball joint driver's side looked like it may have been leaking out some lube. It was hardened and crusted on the inside of my rim.
Driver's Side - Upper Ball Joint and Control arm
Driver's Side - Lower Ball Joint possibly leaking
Driver's Side
Passenger's Side - Upper Ball Joint and Control arm
Passenger's Side - Lower Ball Joint, much cleaner
Passenger's Side
Old Aug 15, 2011 | 08:43 PM
How many miles are on those outer lower control arm bushings? If over 100K, it might be prudent to replace those.
Old Aug 15, 2011 | 10:52 PM
JRhodes88's Avatar
Just to replace the whole lower control arm?
As far as I'm concerned they have 127k on them
Old Aug 17, 2011 | 11:43 AM
pmptx's Avatar
Honda+Blue=My garage
I got a clunk when the mount point for the sway bar actually broke. Had to get it rewelded. check them out
Old Aug 17, 2011 | 02:56 PM
The reason I asked about the miles is because of the slight dimpling noted at the bottom of the outer bushing(s). I replaced my OEMs at about 110K or so, on my CL-S6, with Moogs and nine months later they split. Then I went back to OEMs and figured I would try to get another 110K before I had to dick with them again.
If you replaced the whole LCA's, you would kill two birds with one stone, especially if they have 127K on the clock. Inner and outer bushings.
Or, if you are industrious, one could just remove the LCA, purchase new bushing(s) and replace them DIY or have a local machine shop press them.
Old Aug 17, 2011 | 05:38 PM
JRhodes88's Avatar
Yea, I would just replace the whole thing if I did it. The OEM ones are pretty expensive, about $137 is the best price I can find. I did find some aftermarket like-OEM ones on eBay for around $50 each. Anything known about those?
Old Aug 17, 2011 | 06:11 PM
lol, you think that's bad, try having to replace the knuckle assembly(s) because the ball joints from the factory have the letter (B) stamped on them per Acura Service Bulletin 06-015; dated June 21, 2006.
My friends said to just have the old OEMs pressed out and to press in some new Moogs. The problem (not really a problem hehe:wink: ) I have is the added weight of the S/C'er attached up front. Having a BJ fail while doing 75mph on I95 after going over an overpass with uneven pavement is not something I want to experience in my lifetime. So, I bought new knuckles and moved on.
I would bet they are China knockoffs, no thanks.
Here's a suggestion. You are in Orlando. Go to First-Class Automotive; 3608 East Colonial Drive (407)228-2849. Talk to Nabil, he does all aspects of Acura repair. He is known for his work on NSXs on NSX Prime.com. He may be able to narrow down your 'clunk' and save you potential time/money in resolving the issue.
Good Luck!
Old Aug 18, 2011 | 07:16 AM
JRhodes88's Avatar
Good Luck!
So sorry to hear about your S/C'r problem, haha. I've been trying to get that shop's name for a while now. Do you think he can remove my mid-muffler also? I was going to have that done anyway from there, and maybe he can look into this current problem for me as well. Thanks Again!
also: Is this the correct bushing if that is the case? http://www.jegs.com/i/Moog/719/K9761/10002/-1
Old Aug 18, 2011 | 01:11 PM
It's worth a try. When I was in the area, they did my alignments at the time I worked on my LCA bushings.
Read the thread below before opting for Moogs:
https://acurazine.com/forums/2g-cl-tires-wheels-suspension-54/simple-ball-joint-separation-740248/
If you must go with Moog, check out RockAuto.com. They have better prices.
Old Aug 18, 2011 | 09:10 PM
99TLAcura's Avatar
Hey man check the top of your ball joint to see if is hitting the chassi
Old Aug 19, 2011 | 04:44 PM
TLer trash's Avatar
Just like swllen cu said, now 99TLAcura, now I'll join in...... the adjustable ball joints cause the upper control to ride an inch or more higher than it normally would. It almost looks like it's hitting in your photos. My eibach set up sat higher than yours is, and they hit all the time. Look right above the outer end of the control arm and you'll see where it's been hitting.
Old Aug 20, 2011 | 01:03 PM
JRhodes88's Avatar
Which photo in particular are you talking about? Drivers side or passenger?
MrHeeltoe
20
Feb 23, 2023 01:54 PM
Acura604
2G RDX Photograph Gallery
27
Oct 8, 2020 09:24 PM
Jul 16, 2017 07:33 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
