extended non-use of lowbeams
Old Sep 5, 2005 | 04:58 PM
JayPolosTLS's Avatar
My low beams have been blown out for over 3 months. I barely do any night driving, so it really hasn't been much of an issue. I've been driving occassionally with my highbeams on. My question is, will I have any issues with my ballasts due to not having a functioning bulb connected? How can you tell if your ballasts are in working condition?
Old Sep 6, 2005 | 03:31 PM
03CoupeV6's Avatar
05 C230K & 09 135i 6MT
Replace the bulbs?
It shouldn't harm the ballasts... unless they're the reason the lowbeams aren't working.
Old Sep 7, 2005 | 08:18 AM
Dare_IL's Avatar
Need a WHAmbulance
Like 03CoupeV6 said, unless the ballast are the reason the low beams aren't working shouldn't be a problem. When the highbeams are on, the low beams are also on. So unless there is a ballast problem there is still power going to the low beam light bulbs.
Old Sep 7, 2005 | 07:37 PM
Alright, but how can i tell whether the ballasts are functioning or not?
Old Sep 7, 2005 | 11:47 PM
03CoupeV6's Avatar
By putting a working bulb in them, that's what I meant by "replace the low-beams?"
Old Sep 8, 2005 | 08:11 AM
Dare_IL's Avatar
Need a WHAmbulance
Replace the bulb with a new one or you can use a volt meter. I wouldn't have the volt meter hooked up when you first turn them on. I think the initial volts is like 100k but then goes to 35w for normal operation.
Old Sep 8, 2005 | 02:45 PM
GaryBear's Avatar
Here is technical info about how HID lights work:
How HID lights work
cycdaniel
Dec 17, 2019 10:58 AM
chasingthecool
Mar 9, 2017 05:16 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
Sep 21, 2015 08:44 AM
Sep 17, 2015 10:16 AM
