Crank bolt problems
Old Jul 17, 2009 | 10:16 AM
JRhodes88's Avatar
Need an OEM lip kit on my
Crank bolt problems
Im doing the timing belt as I speak. What is the best way to get the crank bolt off without breaking it?
We are using a 160psi compressor with a impact gun and the bolt wont budge.
please help.
Old Jul 17, 2009 | 10:34 AM
fsttyms1's Avatar
You wont break the bolt. You need either a better impact gun (which really isnt recommended to remove the bolt) the special tool and a breaker bar or you can use the starter method. Place the breaker bar on the bolt so that it rests on the frame or if long enough the ground and quickly (without starting the car) tap the key so that it just starts to turn the motor over and it will break free the bolt. You can pull the ecu/fuel pump fuse so that it wont start to be safer.
Once you break it free MAKE sure to go back and get the crank to TDC #1
Old Jul 17, 2009 | 10:39 AM
JRhodes88's Avatar
thanks. i got my laptop in my garage ill keep you informed
Old Jul 17, 2009 | 10:53 AM
JRhodes88's Avatar
Got it out. using breaker bar and turning ignition.
Thanks for your help. you honestly saved the day
Old Jul 17, 2009 | 11:20 AM
01tl4tl's Avatar
a note- the bolt is set at 181 foot pounds torque
Not surprising a 160psi compressor- minus loss of power thru the tool wouldnt break it loose
See the DIY on crank pulley for tightening tips- example set to 120 ft lbs plus 3/4 of a turn of the socket past that--check,, but thats close on numbers iirc- it will bring it to 181 if followed. needs to be tight!!!
Yes its ok to jam a prybar into the flywheel teeth- remove inspection panel on trans for access to flywheel- that will stop engine turning while tightening bolt
Old Jul 17, 2009 | 11:40 AM
JRhodes88's Avatar
thanks, quick question...is there a reason I got two oil seals in the package?
Do i take the oil filter housing off to get to the oil pump to change those seals? or should I not worry about it?
Old Jul 17, 2009 | 12:12 PM
acutee's Avatar
The oil seals are for the crank shaft and the camshafts. It is not for the oil pump. It is up to you to change the seals or not to change them. They normally don't fail that soon.
Old Jul 17, 2009 | 02:51 PM
AlanW's Avatar
2006 NBP TL MT6/ 02TL-S
It usually takes a 3/4" drive impact wrench and lots of air pressure to zip crank bolts out.
Using some never-sez or whatever you call it when re-installing might make it a little easier to get out just in case there is a "next time".
Old Jul 17, 2009 | 08:06 PM
TLer trash's Avatar
Just fyi Tom, a lot of 1/2" impact wrenches these days are rated at 450 to 600 ft. lbs. at 125 psi with reasonable air flow. I had an accord that wouldn't come off with a 1" impact I borrowed from the bus garage. The scary part was that it moved about 1/8 of a turn. It would have been the third belt, the car had about 275,000 on it so I recommended looking for a new car. The correct tool and 6' of cheater pipe made no difference.
Old Jul 18, 2009 | 05:24 PM
JRhodes88's Avatar
Everything went well and the car is running great. Thanks for all the help.
I don't know what is wrong with my dad's air compressor. It is a 200psi Dewalt compressor but for some reason it was only holding 160psi of pressure.
Old Jul 22, 2009 | 09:21 AM
SYLKIE's Avatar
Wye-Ey-Fore Sicks-Spd
I'm planning on doing my timing belt this weekend, and i'm gonna use the starter method to remove the bolt, but as for reinstalling it, would just using an impact gun suffice? or is it necessary to remove the tranny inspection panel and jam the flywheel?
Old Jul 22, 2009 | 10:37 AM
fsttyms1's Avatar
The rating and psi are one thing BUT there is something else called CFM. Many of those larger guns require a high CFM and a larger dia hose 3/8 instead of 1/4 like most hoses to operate at max potential. Most of the 25-30 gallon portable compressors dont have enough to operate some of those air tools to their max rating. My gun with my old compressor at 125psi would never break the crank bolt. WIth my new compressor at the same 125 it breaks it free just fine.
Old Jul 22, 2009 | 05:08 PM
TLer trash's Avatar
Good point. I did mention with reasonable flow, but I was too lazy to look up and list a real cfm rating. At the time, I didn't think of it, but I can just imagine a diy'er with a new shiny 3/4" impact from harbor freight and a pancake air compressor from home depot.
Old Jul 22, 2009 | 09:11 PM
fsttyms1's Avatar
I have seen stranger things on this forum.
Old Jul 28, 2009 | 01:56 PM
SYLKIE's Avatar
sooo....lemme rephrase that then: how do you get the crank bolt back on tight enough?
cycdaniel
Dec 17, 2019 10:58 AM
Soul_Deamon
4G TL Problems & Fixes
Nov 2, 2015 04:32 PM
mossman77
1/2G MDX (2001-2013)
18
Sep 16, 2015 12:21 PM
whitesoxsfan12
Sep 13, 2015 02:09 PM
NSolace
Sep 3, 2015 08:14 PM
