clunking sound when turning.
Old Jul 14, 2008 | 07:43 PM
sfont012's Avatar
here comes the snow!
ok guys, lookin for some help here.
I noticed my car has been making what i can best describe as a clunking noise. it usually happens at low speeds and i noticed today it mostly happens when i'm turning.
I hear the sound when i'm sitting in the driver seat, and i can hear it coming from the center console area or beneath the center console area, right where you would rest your right arm behind the cup holders.
there are no loose items in the car such as cd's etc etc, i have ruled that out already. it sound like it has to be coming from beneath the car and almost always happens when i turn a corner at low speeds. it kinda sounds like something moving or loose beneath the car.
tryin to get an idea before i take it to the stealership. any help would be appreciated.
Old Jul 15, 2008 | 09:48 PM
6spMike's Avatar
Mike's Silver Bullet
A clickity click that increases with vehicle speed?
Worse when you apply more throttle?
CV joints.
Old Jul 15, 2008 | 11:11 PM
01tl4tl's Avatar
lowered? could be an exhaust mount loose- being in the middle of the car like that,
and check the cv axle bearings- as noted above
Sway bar mount- end links ok?
Old Jul 16, 2008 | 07:40 AM
sfont012's Avatar
good guess ill check for loose exhaust mount. if it is the cv axle bearing, is that an expensive fix?
Old Jul 16, 2008 | 08:09 AM
01tl4tl's Avatar
new cv axle assembly- $75-110 see napa auto parts for brand new ones
labor 1 hour or less
Any of the rubber boots torn on the axle??- thats an instant bearing killer
open the windows so you can hear, and go full lock on the steering input to one side- now drive forward as slow as possible - a few MPH- click click click is cv joint for sure
try the other direction-same or different?
Old Jul 16, 2008 | 09:57 AM
fsttyms1's Avatar
It may be a ball joint or sway bar endlinks. Sounds travel and can be hard to locate. Especially when moving.
Old Aug 13, 2008 | 03:12 PM
9932's Avatar
2G wanting 3G
i'm having somewhat of the same problem. i hear a noise from the front passanger side. happens sometimes when i turn the wheel while parked. happens more often while driving. it gets faster as i drive faster. hitting the breaks does not effect the noise and theres nothing stuck to my tire. i can best describe the sound as someone runing in wet shoes. cv boots? rack? suggestions welcome.
Old Aug 14, 2008 | 07:40 AM
9932's Avatar
2G wanting 3G
i went in an empty parking lot yesterday so i could drive in circles. with wheels pointed left, no sound. with wheels pointed right, i slight squeak. i felt the cv boot and squeezed it, no tares. its a rubber squeaking sound. is there a bushing that goes bad? i thought our ball joints were sealed, do they need grease? please help, its embarrasing to drive with this noise.
Old Aug 14, 2008 | 04:58 PM
totaledTL's Avatar
Mine developed an annoying squeak at approx. 90K miles- turned out to be a lower ball joint.
Old Aug 16, 2008 | 01:34 AM
thuanss314's Avatar
7th Gear
i think im experiencing the same thing with my car. well not exactly the same but close. like everytime i slow down to a stop i feel a clunk under my foot. it so annoying and i have no idea whats doing it.
Old Aug 16, 2008 | 02:01 AM
thuanss314's Avatar
7th Gear
hmm i read up some stuff about cv joint failure.. seems possible?..
Old Aug 16, 2008 | 09:11 AM
9932's Avatar
2G wanting 3G
found the problem. this is gonna sound crazy but the place i took it to for balance and rotation didnt torque the wheels down all the way(stupid torque sticks) and for some reason that loose wheel sounded like squeaky rubber. i took it to a shop and they thought it was a bushing. they sprayed down the boot and joints with some grease in a can type stuff and nothing changed. they checked for play in the wheel and nothing. then they had me drive it back and forth slowly in the driveway so they could watch and hear what was goin on. the guy jumps up , grabs his impact gun, tightens the lugs, NOISE GONE.
Old Aug 19, 2008 | 11:23 AM
sfont012's Avatar
wow nice easy fix, your lucky. wish i could figure mine out but got no dough. brizoke. mayb next week. noise drives me crazy! every time i turn!!!!
mlody
Dec 4, 2019 02:11 PM
DerrickW
Nov 15, 2015 05:52 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
hashbrown
Sep 29, 2015 12:13 PM
Brandle34
Sep 23, 2015 07:20 PM
