clicking noise under driver seat...
Old Feb 23, 2007 | 09:39 PM
jvue's Avatar
I have a weird clicking noise under the car after driving the car in 3-4 miles.. it only click when the car is in park.. but if i rev the car to 2500-3000rpm.. the clicking noise goes away... then it goes away and never come back until driving.. have anyone experience this kind of problem before.. if so any suggestions..
Old Feb 28, 2007 | 07:32 AM
honda inspiration's Avatar
7th Gear
i have the exact same problem but took it to the acura dealership to repair and they said there is nothing they can do. something like it had to do with the fuel line, not to sure, but i hate it, these may not be maybachs, but they are considered luxury , and shouldn't be making these noises. someone with knowledge please respond.
Old Feb 28, 2007 | 08:50 AM
fsttyms1's Avatar
is it more like a ticking noise by the drivers side rear wheel?
Old Feb 28, 2007 | 10:01 AM
7th Gear
i notice it there, yes, only when i am outside the car, from the drivers seat it sounds as if it is coming from the engine compartment, right behind the steering column
Old Feb 28, 2007 | 04:01 PM
fsttyms1's Avatar
Well you have 2 different noises. One is the Purge control solenoid (the noise heard from in the car) and the EVAP canister noise. Both are semi normal, neither mean there is a problem. Neither will harm the car. You can replace them if you want. the sound typically goes away in warmer weather.
http://www.acuraautomotiveparts.org/...catdisplay.jsp
Old Mar 1, 2007 | 07:38 AM
7th Gear
thank you
Old Mar 29, 2007 | 07:52 PM
overlook2k's Avatar
I have a similar noise but from the passenger side and it is when I start the car sometimes. Rev it up and it goes away. But its a clicking and if I put my hand on the passenger side floor against the console it is directly behind there. I was wondering if there may be a relay behind it acting up. I dont know what would cause this thump because I can feel it! Any ideas?
Old Mar 30, 2007 | 08:45 AM
sharkon's Avatar
hey, thanx for reply, could you plz tell me the OEM-numbers of those parts the noise is coming from?
Old Mar 30, 2007 | 12:35 PM
fsttyms1's Avatar
In that link, follow the instructions to get the correct car and year, then go to fuel pipe. Its Part #5
Its the Evap Canister
Old Apr 1, 2007 | 07:03 AM
sharkon's Avatar
Thanx!
Old Apr 5, 2007 | 04:46 PM
ThreePointTwoTeeEl's Avatar
3.2TL
I have the same problem, but its when I go over a small bump or something, the seat like rattles, or even if I push the seat from the back a lil, it makes like a clicking noise, like if something is loose, its the drivers seat.
Dec 7, 2020 05:39 PM
Feb 25, 2020 09:57 AM
snorf
Nov 4, 2019 06:44 AM
gemz_acura
4G TL Problems & Fixes
15
Sep 26, 2015 06:12 PM
Steven Vitek
ILX
Sep 10, 2015 07:29 AM
