99 3.2TL dies while driving, security light flashes
Hey everyone,
My buddy just bought a 99 3.2TL and a few days after he bought it, it suddenly started cutting of on him at random times while he's driving!!! He said the security light flashes like it has something to do with the factory alarm cutting off the car. I thought ya'll would know if anyone does. Anyone ever heard of this? And if so, what's the fix??
Thanks.
Sandlapper
Thanks.
Sandlapper
Originally Posted by Eisenhulk
Tell him to replace the ignition switch. Search the forum....I just replaced mine a few months ago.
It's simple.
It's simple.
First, Your buddy needs to find out if the car has had the ignition switch recall done on the car.
He can find out by registering at acura.com under owners link. It will tell if its been done or not. If not thats a good place to start.
Search "ignition switch."
It seems like it could be the ignition switch, but since the security light flashes I'm wondering if it's something to with the alarm. For instance NSXNEXT, a moderator on this board wrote this about his car:
Check this:
When the car cuts out, does the radio and air work but not the windows & turn signals?
If so it is without a doubt the ignition switch. Mine did the same thing. Turns out my problem was my alarm was cutting power to the ignition switch.
It basically behaves the same way as if you turned the key to position 1 (the first click after you put the key in).
Originally Posted by Sandlapper
Yeah, I searched that.
Check this:
Check this:
My issue was with an aftermarket alarm (Clifford Intelliguard 9000) not the stock immobilizer system.
So you think it's the ignition system from what I've said?
Yes, Try the stuff i mentioned. If it still does it its either the ignition again or the immobilizer
Originally Posted by sharroll
I just had my ignition switch replaced Wed 4/4/07. Called Acura and they said it was recalled, so tell him to call any Acura dealer and they should replace it!
did he take the acura back
mada51589
Jan 9, 2025 04:40 PM
RLX-Sport Hybrid
3G RLX (2013+)
43
Dec 16, 2015 10:45 PM
