Check engine light, and low idle.
Old Mar 24, 2008 | 02:09 PM
ryebreadisme's Avatar
Low and Slow
I just cleaned the EGR valve and intake manifold. Now the I have the symptoms in the title.
Low idle, and Check engine light.
Any thoughts?
Thanks for the help in advance.
Old Mar 24, 2008 | 02:30 PM
bibledriver's Avatar
Something is missing...my
possibly wrong retorque pattern and spec?
Have you reset the light/cpu to see if it kicks the code again and also let it relearn with better flow?
Old Mar 24, 2008 | 02:32 PM
Low and Slow
I have not checked the torque...
I guess I'll have to do that when I can get my hands on a torque wrench. I haven't reset the battery either...
Old Mar 24, 2008 | 02:55 PM
Low and Slow
I disconnected the battery and now I'm going to wait and check it in about ten minutes.
Old Mar 24, 2008 | 03:02 PM
Never know.
And if you didn't use a torque wrench when putting IM top back on that may be detrimental.
it also states a specific pattern to apply bolts (kinda like when you put your wheels on) which is probably stated it the DIY
Old Mar 24, 2008 | 03:04 PM
Low and Slow
I followed the torquing pattern, but not torque spec. Last time I took it off I did not do either and no light then.
Do you think it could be the cleaner I used to clean the IM?
Old Mar 24, 2008 | 03:08 PM
possible but hard to say. I have not done this EGR/IM cleaning yet. Typically vacuum leaks make the idle high, but with the CEL on, the cpu has gone to default settings rather than dynamic.
See what happens with the reset.
Did you use a different type of cleaner this time?
Old Mar 24, 2008 | 03:13 PM
Low and Slow
I used brake parts cleaner as recommended by a manager at autozone....
Old Mar 24, 2008 | 03:21 PM
I think that you would be better off with mass airflow sensor cleaner being that it is more specifically safe on electrical sensors.
Old Mar 24, 2008 | 03:22 PM
Low and Slow
Hmmm....I really don't think I would have affected any electrical sensors though. I removed the manifold before I began spraying. I don't know what the problem is if this reset doesn't fix it.
Old Mar 24, 2008 | 03:28 PM
could be right, That is just what I would do in fear. If it doesn't reset, then you'll just have to pull the codes. Could be the raw cleaner getting through onto the O2 sensor too. Hard to say.
See what happens with reset.
Old Mar 24, 2008 | 03:35 PM
Low and Slow
Lights off so I guess the reset is all it needed! Thanks for the chat though!
Old Mar 24, 2008 | 03:45 PM
Old Mar 24, 2008 | 07:12 PM
6MTUA5's Avatar
No He Can't
Also check all the vacuum hoses to make sure there are no air leaks.
Old Mar 24, 2008 | 07:18 PM
fsttyms1's Avatar
Next time a carb/ throttle cleaner would be better and safer for the sensors
MikeYutkin
Sep 10, 2015 10:13 PM
Bahamanurse1
Sep 10, 2015 10:05 PM
HeloDown
Sep 8, 2015 06:51 PM
bryan zaragoza
Sep 8, 2015 12:28 AM
whitesoxsfan12
Sep 7, 2015 04:07 PM
