check engine light and flashing
Old Mar 14, 2009 | 07:09 PM
thinhthan's Avatar
Exclamation check engine light and flashing
i got in my car this morning to go to class and i started up. everything seem normal until i put it into drive and thats when the car started to like kinda putt kinda. i started driving and about two min later the check engine light comes on. after a few seconds after the light went on it started flashing. so i drive the car home and about five hours later i drove it to autozone to get a dtc scan. the scan said i got five codes. P0301,p0303,p0305, those are misfiring in cylinder 1, 3, and 5. the other codes are p1399 which is random misfiring. and i also got a p0300 which is another random misfire detected. do anyone got any ideas what could be wrong. i need the car to drive to school monday and stuff and i dont wanna keep driving the car in this condition.
Old Mar 14, 2009 | 07:26 PM
Sal's Type S's Avatar
If you can try and do a tune up this weekend. Plugs, cap and rotor.You do not want to drive with a missfire thats why your check light flashes when it misses. If you continue to drive it you can ruin your CAT converters.
Old Mar 14, 2009 | 07:29 PM
thinhthan's Avatar
i changed the plugs like two three months ago. i thought we dont got a cap and rotor? i though we have coil on plugs.
Old Mar 14, 2009 | 08:04 PM
Gfaze's Avatar
S E L L
One of your coils is most likely bad. Go buy one coil ($50?) and replace one of your coils, still flashing/running bad? Remove it, put the old one back in, pull out the next one over, try again. Do this until you find the bad one. Do not drive your car while the light is flashing, you will ruin your catalytic converter because you will essentially be dumping raw fuel in it. It's not designed to burn raw fuel.
Old Mar 14, 2009 | 08:14 PM
thinhthan's Avatar
if its one coil that is bad wouldnt only that cylinder misfire?
Old Mar 14, 2009 | 11:46 PM
thinhthan's Avatar
i guess im start off with cleaning the egr valve. than what else should i start off doing?
Old Mar 15, 2009 | 12:33 AM
gshantanu's Avatar
I agree with gfaze. It must be one of the coils. Even if one of them is dead, all cylinders misfire. I have experienced this first hand, so I am quite sure. I would say that before working on EGR cleaning, try to resolve the real issue first. Good luck...a single coil costs about $45.
Old Mar 15, 2009 | 02:24 AM
thinhthan's Avatar
ok so im misfiring in cylinder 1 3 5. so should i buy a new coil and put it in cylinder one first? than put it in 3 than 5? how will i know which one is bad?
Old Mar 15, 2009 | 02:51 AM
Gfaze's Avatar
S E L L
For some crazy reason, even though you may only have one cylinder misfiring, the computer will generate multiple cylinder misfires. It's almost always only one though. Try the steps I posted earlier and see what happens.
Old Mar 15, 2009 | 07:05 AM
juanclopez2786's Avatar
i agree with gfaze... just get 1 coil clear the light put it in cyl 1 drive it. if the light comes back on check it and if its 1 3 5 again go and put the new one in 3 and so on and so forth til the light doesnt come on. 1 bad coil causes the other cylinders to misfire..
Old Mar 15, 2009 | 08:27 AM
fsttyms1's Avatar
You need to search Misfire. You will see that our cars will show multiple misfires for just 1. Buy 1 coil and start with it (i would start on the ones that show that its misfiring) reset the ECU each time you try it on a different cyl.
Old Mar 15, 2009 | 01:29 PM
thinhthan's Avatar
ok thanks ima try that
Old Mar 15, 2009 | 11:08 PM
Was not thinking your right coil on plug. Another thought could be water big puddle that ypu might of gone through.
Old Mar 15, 2009 | 11:46 PM
thinhthan's Avatar
i never went through any puddles or anything
Old Mar 16, 2009 | 01:39 PM
That's weird its. But it seems that maybe a camshaft or a crankshaft sensor since its only every other CYL that's doing it.
Old Mar 16, 2009 | 07:54 PM
did you try swapping around coils 1-2, 3-4, 5-6.. reset light and see wut cylinder misfires. its your easiest way. if it still comes up 1,3,5 then try moving around plugs. norrow it down through process of elimination..
Old Mar 16, 2009 | 09:20 PM
sleeperblue's Avatar
Had the same problem, got new plugs, cleaned the EGR, swapped coils (bought a new one), ended up taking it to a garage (my $$$ mistake...) it ended up being 3 bad injectors. The car runs great now, although the VSA and 'triangle' lights are still on...no codes anymore.
Old Mar 16, 2009 | 11:39 PM
Gfaze's Avatar
S E L L
Bad injectors can cause it too but it's not likely. It's more common for it to be a bad coil.
Old Mar 17, 2009 | 10:42 AM
You'll have to take it to the dealer for the code under the VSA system
Old Mar 17, 2009 | 12:14 PM
thinhthan's Avatar
i dont got vsa. but i already bought a new coil and replaced cylinder 5 and it runs now. the check engine light turned off while i was driving so thats a good sign lol
Old Mar 17, 2009 | 06:35 PM
mstaj10's Avatar
Dude i jus got my checked at midas for the exact same thing...and i got the 1399 code to..they said somthing about my exhaust filter and and it being blocked by carbon...they didn even charge for the diagnostic, bcuz he knew an acura dealler was gonna kill my pockets for it....they said to get it fixed its like scope surgery u gotta go in w/ a cam and all that crap.....
Old Mar 19, 2009 | 07:09 PM
Exhaust filter there trying to rip U off. The only thing that resembeles a filter is the CAT converter. The only other thing that gets plugged op is the EGR pasage ways and that only on high milage vehicles that run dirty(burn oil exesive fuel).
Old Mar 20, 2009 | 02:54 AM
Gfaze's Avatar
S E L L
It sounds like they didn't know exactly what was wrong with it since that explanation doesn't make much sense. Take it to a good mechanic/shop and have them do a diagnostic and see what they say. Midas is not the place for diagnostics, just basic maintenance.
Old Mar 24, 2009 | 08:24 PM
acurabum's Avatar
I got P1399 multiples misfires on my tl-p 02 too after Sportshifting in 3th to almost the red zone ..car pulling strong and great but Engine light flashing ...slow down a bit and light went off ....15 minutes later put it back in 3th to red zone and engine light flash .......
Do you guys think I got a coil or injestor fouling ?
thanks for your input
Old Apr 6, 2009 | 09:27 AM
mstaj10's Avatar
Wassup my brothas just to let u kno i got my problem worked out. they told me it was actually engine coils...i took it to an acura dealer they only hit me for $204. thats w/ the price of a diagnostic. just in case ur still have this prob.
MikeYutkin
Sep 10, 2015 10:13 PM
Bahamanurse1
Sep 10, 2015 10:05 PM
HeloDown
Sep 8, 2015 06:51 PM
bryan zaragoza
Sep 8, 2015 12:28 AM
whitesoxsfan12
Sep 7, 2015 04:07 PM
