check engine light and flashing
i got in my car this morning to go to class and i started up. everything seem normal until i put it into drive and thats when the car started to like kinda putt kinda. i started driving and about two min later the check engine light comes on. after a few seconds after the light went on it started flashing. so i drive the car home and about five hours later i drove it to autozone to get a dtc scan. the scan said i got five codes. P0301,p0303,p0305, those are misfiring in cylinder 1, 3, and 5. the other codes are p1399 which is random misfiring. and i also got a p0300 which is another random misfire detected. do anyone got any ideas what could be wrong. i need the car to drive to school monday and stuff and i dont wanna keep driving the car in this condition.
i changed the plugs like two three months ago. i thought we dont got a cap and rotor? i though we have coil on plugs.
One of your coils is most likely bad. Go buy one coil ($50?) and replace one of your coils, still flashing/running bad? Remove it, put the old one back in, pull out the next one over, try again. Do this until you find the bad one. Do not drive your car while the light is flashing, you will ruin your catalytic converter because you will essentially be dumping raw fuel in it. It's not designed to burn raw fuel.
I agree with gfaze. It must be one of the coils. Even if one of them is dead, all cylinders misfire. I have experienced this first hand, so I am quite sure. I would say that before working on EGR cleaning, try to resolve the real issue first. Good luck...a single coil costs about $45.
For some crazy reason, even though you may only have one cylinder misfiring, the computer will generate multiple cylinder misfires. It's almost always only one though. Try the steps I posted earlier and see what happens.
i agree with gfaze... just get 1 coil clear the light put it in cyl 1 drive it. if the light comes back on check it and if its 1 3 5 again go and put the new one in 3 and so on and so forth til the light doesnt come on. 1 bad coil causes the other cylinders to misfire..
You need to search Misfire. You will see that our cars will show multiple misfires for just 1. Buy 1 coil and start with it (i would start on the ones that show that its misfiring) reset the ECU each time you try it on a different cyl.
did you try swapping around coils 1-2, 3-4, 5-6.. reset light and see wut cylinder misfires. its your easiest way. if it still comes up 1,3,5 then try moving around plugs. norrow it down through process of elimination..
Had the same problem, got new plugs, cleaned the EGR, swapped coils (bought a new one), ended up taking it to a garage (my $$$ mistake...) it ended up being 3 bad injectors. The car runs great now, although the VSA and 'triangle' lights are still on...no codes anymore.
Dude i jus got my checked at midas for the exact same thing...and i got the 1399 code to..they said somthing about my exhaust filter and and it being blocked by carbon...they didn even charge for the diagnostic, bcuz he knew an acura dealler was gonna kill my pockets for it....they said to get it fixed its like scope surgery u gotta go in w/ a cam and all that crap.....
there trying to rip U off. The only thing that resembeles a filter is the CAT converter. The only other thing that gets plugged op is the EGR pasage ways and that only on high milage vehicles that run dirty(burn oil exesive fuel).
I got P1399 multiples misfires on my tl-p 02 too after Sportshifting in 3th to almost the red zone ..car pulling strong and great but Engine light flashing ...slow down a bit and light went off ....15 minutes later put it back in 3th to red zone and engine light flash .......
Do you guys think I got a coil or injestor fouling ?
thanks for your input
Wassup my brothas just to let u kno i got my problem worked out. they told me it was actually engine coils...i took it to an acura dealer they only hit me for $204. thats w/ the price of a diagnostic. just in case ur still have this prob.
HeloDown
Sep 8, 2015 06:51 PM
