check engine light
my check engine light came on when I hit 60 mph but then disappeared. next day driving I hit 60 mph again the light came on again but this time it stayed on. the car seems to be driving normal but I want to know why the check engine light is on and if it's going to be a problem. please respond I need help!
the p03xx codes are misfire codes. i just encountered a similiar issue. a new ignition coil fixed the problem.
this'll help you out...
https://acurazine.com/forums/2g-tl-problems-fixes-117/codes-p0300-p0306-p1399-random-misfire-help-720450/
its most likely 1 coil is failing,the other threads will guide you thru how to find which one
Buy a coil from parts store- about 50 bucks
whats the cars mileage now?
ckd any other parts like spark plugs to see if they have ever been replaced?
do NOT drive in SS mode of the trans at 60 in 2nd,,thats going to cause probs with the trans at the least
thats got to be close to redline,,ok to go there and shift up, but sustained high rpm lower gears is not ok
I bet it has the original plugs since the book allows them to go to 105 but the reality is the car runs better with new ones after 60-70kmiles
So thats one thing to consider,,if they are toast they can generate a misfire code
use NGK Iridium, iridium IX or platinum
car came with plats but gen3 has irids and we can use them as an upgrade in quality of plug--about 8 bucks each
are you on 91 octane gas ONLY,,or 94 if thats what is premium in your area
register with `acura care` USA 1 800 382 2238 x5 gets a human
canada ziners use 1 888 9acura9,,has different website too
have cars VIN in hand-tell them you are the new owner and need a `recall ck`,,make sure all are completed and any warranty repair history they can tell you about
also reg on their website ,,you can store the radio and nav codes there for safety
http://owners.acura.com/registration...istration.aspx
allows you access to the entire owner operator book- the TL has many trick systems including how to use the trans,,,the auto climate control,,nav, abs system-traction control that activates a brake on spinning wheel and much more
congrats on your purchase!
my suggestion is remove a front plug and inspect for wear
replace them, run seafoam thru the tank and manifold
and do the coil test procedures
note- reset ECU after you find a dead coil,.remove the `CLOCK fuse` on passenger end of dash for 1 minute,,that forces a master reset and system test..like pulling the plug from the wall on your home PC
It clears all the codes so you start fresh on diagnostics to see if its fixed
we will get you thru this no sweat and make your baby purr
New-To-Me TL
I just got my TL almost two weeks ago and I didn't know you could get all that background info. Thanks for the info
congrats on your purchase![/quote]
HeloDown
Sep 8, 2015 06:51 PM
