Changing Fog Light Bulbs
Old May 8, 2006 | 09:56 AM
sittin pretty's Avatar
Any1 have a quick way of replacing a fog light bulb???
Thanks!
Old May 8, 2006 | 11:50 AM
death's Avatar
If you look under the bumper there is a small square cut out on the bottom of the bumper. If you look into this cut out you will see the bolt that holds the fog light in place.
Use the following to remove the bolt:
8 mm socket + ratchet extension (depending on whether or not you have an OEM kit...)
Fog Light removal:
Get a small screwdriver and cover the tip with a soft material (I used a piece of paper towel). Slide the screwdriver in between the fog light and the bumper on the left side of the fog light (assuming your removing the right fog light when looking at the front of the vehicle). The fog light should just pop out. Don't apply to much pressure...
Old May 8, 2006 | 11:58 AM
thanks.. i will give it a try today!
Old May 10, 2006 | 03:33 AM
smaroof's Avatar
5th Gear
what is a good hyperwhite bulb to put here? I was thinking PIAA is best
Old May 10, 2006 | 10:23 AM
snowman81's Avatar
Sippy Cup (x2)
PIAA Xtreme Force...about $90 for a pair. They match the HIDs very well from what I've heard. TL Dustin had them on his 2nd Gen.
Old May 11, 2006 | 01:37 PM
smaroof's Avatar
5th Gear
btw what is the bulb number?
Old May 11, 2006 | 02:40 PM
snowman81's Avatar
Sippy Cup (x2)
9006
Old Dec 23, 2011 | 04:18 PM
donsbach23's Avatar
10 mm
Thanks for the tips on changing the fog light. Although on my 2002 TL 10MM was necessary, not an 8 MM rachet.
Old Dec 29, 2012 | 11:25 AM
sallendtp's Avatar
Anyone actually have the number for the fog bulb? 9006 is for the headlight I believe. Looking to get new FOG BULBS not headlight bulbs. Thanks in advance
Old Dec 29, 2012 | 11:30 AM
03tLsNBP's Avatar
MechEng
headlight - D2R
high beam - 9005
fog light - 9006
Old Dec 29, 2012 | 03:11 PM
HairyMonkey019's Avatar
there is a bulb application in the diy section
Old Feb 10, 2013 | 12:07 PM
snorty's Avatar
2003 White TL
I just posted some pix of the fog light replacement I did today. Easy job, just needed new bulbs (9006), a 10mm socket with an extension and a spudger to get the lamp assembly out.
Old Feb 11, 2013 | 12:11 PM
sallendtp's Avatar
Originally Posted by 03tLsNBP
headlight - D2R
high beam - 9005
fog light - 9006
I replaced all the bulbs. High beams/ Low beams/ and fogs. The passenger ballast had brown sh*t on the plug. I assume it is moisture. Now on the hunt for a ballast. ....
Old Oct 29, 2013 | 02:16 AM
TL260power's Avatar
Any idea where I can get nice aftermarket fog lights with a touch of blue? My aftermarket ones just burned out. (lasted a long time) I don't remember where I got them.
Old Oct 29, 2013 | 04:38 PM
Skirmich's Avatar
^ Autozone and most Auto Parts sells ULTRA WHITE bulbs which are coated with a blue hint on them..
If you want blue color on the light itself go HIDs..
Old Oct 29, 2013 | 06:19 PM
hamburglar490's Avatar
Something to consider if you want the 6K look, are these LED fogs (http://www.vleds.com/bulb-type/drl-f...06-1-pair.html)
I got them and they have pretty good light output(850 LM total output) and they match my 6K HID's perfectly. Had them for about 4 months now and they're holding up fine.
Attachment 109037
Old Oct 29, 2013 | 11:17 PM
Skirmich's Avatar
^ Tough you can get some cheapo HID kits for that Price and will get you 3250lm :/
Old Oct 30, 2013 | 12:08 AM
Hmmm. Well that does seem like the better option lol. On the other hand, these are quicker to install
Old Oct 30, 2013 | 12:10 AM
Skirmich's Avatar
Dont get me wrong! They look awesome and the quick way to get that "HID" look.. But if I were buying that I would wait till I get Looks and Useful light too
Old Oct 30, 2013 | 04:32 AM
vaj47's Avatar
5th Gear
can u run higher watt beside 55w? for the 9006
Old Oct 30, 2013 | 05:17 AM
Skirmich's Avatar
^ Yes but in the fogs is useless they have a Cut off so the light will never show in the Low beam headlight area.. Using 55w will make the light NEAR the bumper stupid bright.. You want 55w in the Lows and 35w in the Fogs.
Old Nov 5, 2013 | 06:55 PM
TL260power's Avatar
Just bought me these. I will see how they look once I get them. http://www.hidextra.com/9006-6000k-hid-kit/
Old Nov 6, 2013 | 12:05 PM
cincinattlguy19's Avatar
06 NBP 6MT TL
Here's my DDM Tuning 6000K kit. This was when I first installed, but since then they have gotten a blue hue to them! I would recommend just putting HIDs in the fogs!
Old Nov 6, 2013 | 05:59 PM
TL260power's Avatar
Just got these today and they are a full kit. I just need the bulbs so I'm going to return them.
Old Feb 4, 2015 | 06:43 PM
TL260power's Avatar
Originally Posted by hamburglar490
Something to consider if you want the 6K look, are these LED fogs (5K WHITE 10 LED DRL/FOG LIGHT BULBS HB4 9006 | 1 PAIR - 9006 HB4 - Fog Lights - Shop Bulb Type)
How many Watts do the fogs lights have?
Old Feb 4, 2015 | 08:09 PM
Skirmich's Avatar
^ According to specs those LEDs pull 7.5W
Old Feb 4, 2015 | 09:06 PM
01tl4tl's Avatar
watts is power used to operate
Lumens is amount of light output
Kelvin is the color scale used for bulbs 3000 5000 6000 etc
3000 is yellow for actual fog, 5000 is best for replacement of stock lights
Old Feb 11, 2015 | 06:30 PM
TL260power's Avatar
Just installed these last friday. Next my headlights.
Attached Thumbnails Changing Fog Light Bulbs-fog-lights-day-version.jpg   Changing Fog Light Bulbs-fog-lights-night-version.jpg
sockr1
Oct 1, 2015 01:31 AM
theinsvnity
Sep 10, 2015 10:22 PM
ellisd03tls
Sep 8, 2015 04:17 PM
cruisingnycfl
Sep 2, 2015 12:11 PM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
