catalytic converter
why do you need a cat is the question- they are warranty covered to 80k miles
Past that- as everyone says- Excelerate has both bargain and $300 performance cats,
and muffler shops should offer the same thing-
not midas type place-but a private owned muffler shop will hook you up with a LEGAL, proper for the TL- cat
I'm tempted because of the good price.
my cat is making that annoying rattle sound even with the heat shield off while driving.
If you don't mind having your check engine light on, there's no problem with aftermarket catalytic convertors. It's pretty common for a catalyst efficiency code to pop up with them. The car will still run fine, and pass emissions. The ONLY real long term solution to the cel problem is the pricey dealer part. Check with our vendors and see if they can guarantee one that will work. There is at least one member on here that has a random technology cat with this problem, and the rt cats are among the best in the aftermarket. Perhaps someone else has had this problem and can suggest a brand that will work for more than a few months.
thanks for your inputs and recommendations.
my muffler shop wants to charge me 300 for the cat convert.
my problem is that I'm still not 100% sure where the noise is coming from.
MY bad. I thought it was already diagnosed. Have it ckecked out before you have a cat installed. I've had way more hangers and shields rattle on honda/acura than convertors.
I've tried 2 big name aftermarket suppliers for honda and others, and have had the code come back in a few weeks. When i did a search on a technicians network, the response to having code p0420 with new convertor was more than 25 to 1.....replace with oe only! I've done a LOT of research into this and I haven't come across 1 instance of an oe convertor doing this. I'd heard of and seen random tech cats in the past, and hoped they might be a solution. I went so far as to get set up as a dealer with them to try next time this pops up. When I talked to the rep on the phone, I asked specifically about p0420 and warranty. There was some hemming and hawing, but sort of an assurance that they would warranty one.
I was thinking about trying one on my own car when last week a poster here reported running an rt cat WITH a plug defouler and still having code p0420. his car didn't have a code prior to replacing the cat.
I've seen one car [not a honda/acura] with NO cat and a non fouler that doesn't throw codes.
Other than gaining information about what will work, my biggest reason for posting on this subject is to save someone from getting the standard treatment when an aftermarket convertor causes a cel.
Typically the car gets blamed..... you need a new rear o2 sensor,well, lets do the front one,it's gotta have new plugs,injector cleaning etc.
I just want to make sure people know the possible outcomes going in.
thanks everyone,
acura said my convertor has an 8 year warranty - which is good news.
if they find that it is the convertor, then my diagnostic fee is waived.
I thought my warranty expires after 3 or 5 years
I usually try to stay away from absolutes so I've got a little wiggle room, but I re-read my post and there's that ONLY word. If you haven't guessed it, I've got a couple cars that I'm currently trying to find reasonable solutions to code p0420. I'd really like to hear from someone who can recommend an aftermerket cat that will not turn on the cel and keep it off for longer than a few months.
There have been MANY who ran the RT cat that Excelerate sells without getting the code. If there is a member getting the code even WITH a defouler its not the cat causing it. He has some other issue, maybe damaged the wiring? or the front O2 is bad, or a ECU issue. I have NO cat and a defouler and i dont get a code!
^^can't PM you yet, but you should join the ATL group here:
https://acurazine.com/forums/groups/atl-17/
we're trying to organize a mini meet this week if you're interested in showing off that RL.....
The cheapest oem cat I found was $583.20 from hondapartsunlimited.com.
Can you point out the model amongst their CAT selection?
https://xlr8performance.com/c-48-sho...onverters.html
You do realize you have posted to a 12 year old thread.
From the link you posted it looks like a 2002 TL would use the following unit https://xlr8performance.com/c-48-sho...onverters.html
it is the only one that fits a 2000-2003 Acura on the website.
Jon M
Yes I do realize the old thread, but knew there are knowledgeable people here that would know... You re-posted the same URL that I posted, yet mention only one CAT that would fit without mentioning which one...?
I did a search for 99-03 and was this one https://xlr8performance.com/i-37219-...ef=category:48
I found one for 80$. Would not spent one cent more as cats are target at acura and honda. https://acurazine.com/forums/second-...ptions-990863/
Jon M
This being said, I did find that Magnaflow/ Bosal (A.K.A. Car Sound Exhaust System, Inc., under California Air Resource Board (https://ssl.arb.ca.gov/AftermarketParts/catalysts)- what mufflers shops use to look up compatible CAT's) with the compatible ESI# for my car (02 TL) was "2X2l" and the corresponding "direct fit" OEM CAT OBED II was the 4481616 (confirmed by Magnaflow over phone). $828 direct from Magnaflow, or about $649 from local trusted muffler shop, used before, and also referenced was the 4481255 for a weld in CAT, but my master mechanic at the local Acura Dealership doesn't recommend cutting out the CAT, and I quite frankly would not want to cut it out in case of any issues and easier to remove if bolt on...
It would appear you might be trying to say that in CA there is no yearly inspection and something about your CAT being compliant?
With this being said, CA has a biannual smog check and to my knowledge it's only if it passes or not. According to my master mechanic at the dealer, they're suppose to check to see if the CAT matches the EIS# with what's under the hood decal.
Mikey 03 TL Type S
Apr 27, 2009 09:21 PM
numbaonexstunna
Jun 14, 2002 09:34 AM
