Catalytic converter stolen what are options?
Old Nov 8, 2020 | 11:18 AM
bbsitum's Avatar
Someone cut it out. Where is best to buy another one. Will have to add some pipe to as they cut big part of pipe to. Would go band clamp route to put it up. Worked well at my F250. What is that wire that is cut? First picture is Acura, another is band clamp with cat at Ford.
Old Nov 8, 2020 | 12:22 PM
looks like a fuel line that was cut?
go to a muffler shop and ask them to put in an "aftermarket cat" or one that isnt an oem.
sure you can band clamp it...that is if you buy your own cat...but since you're asking....it might just be easier to take it to an exhaust shop, as they will have cats on hand.
Old Nov 8, 2020 | 01:03 PM
If I had to guess, probably O2 sensor related?
Sire looks like the o2 sensor wire thats connected to the back cat
Old Nov 8, 2020 | 03:37 PM
bbsitum's Avatar
At page 241 of manual say it is secondary heated oxygen sensor. Sensor and wire are one part. Was at U pull and sow where it disconnect. There at U-pull is not neither sensors or cats, they cut them.
By member "Zeta" in 2011 ===== Denso #234-4727 = Bank 1 (upstream) ================== Denso #234-4621 = Bank 2 (downstream)
Amazon Amazon
Old Nov 8, 2020 | 03:54 PM
bbsitum's Avatar
^^^ As I understand down stream is that one at cat. Btw I have photo of part of cat from past year when I did put new flange bolts in. This is what there steal from me, 17 years old. Original cat is 88$ at internet and universal around same. So they will get 40$ for it at most.
Old Nov 8, 2020 | 04:05 PM
People steal cats to extract the precious metals from it, not for use.
Old Nov 8, 2020 | 04:56 PM
bbsitum's Avatar
^^^ So that mean even less money. Like 30$?
Old Nov 10, 2020 | 01:12 PM
Darksyne's Avatar
Yikes, that sucks op. I got about $360 for my OE cat from a random near by scrap yard when I swapped it out for a high flow one so I can see why people still steal cats from old cars these days.
Probably covered his fix of dope for the week :/
Old Nov 10, 2020 | 04:31 PM
bbsitum's Avatar
^^^ Well thanks to Honda for putting a lot of precious metals into cat to protect this world. However new cat is at way and it cost only 90$, so minimum of metals in it. Probably nobody will want to stole it.
Old Nov 11, 2020 | 04:52 PM
Phuong Pham's Avatar
While you're at it, try to get some new tires. Looks like you're at the wear indicator mark. Really hate to see you hydroplane in the rain on those tires.
Old Nov 13, 2020 | 07:50 AM
bbsitum's Avatar
Cat is conveniently stolen last day before winter. It is 18F here at moment. But should be 45F one week from now. Hope cat will be here till than. Thinking to give to mechanic if will weather be bad when cat is here. Thick layer of ice is on ground at moment to.
Old Nov 13, 2020 | 09:07 AM
UA5_6MT's Avatar
Save the Manuals
i scraped my cat for $275 i could have gotten more but $275 i felt was a good price, they usually can get $300-350. The 4cyl accords and cl are worth more
Old Nov 13, 2020 | 09:29 AM
I have my OEM cat stored in the attic.
Is the going rate that much for the innards of a CL-S6 cat?
Old Nov 13, 2020 | 12:36 PM
UA5_6MT's Avatar
Save the Manuals
yup, that's why they get stolen left and right in nj, ny area
Old Nov 13, 2020 | 04:17 PM
bbsitum's Avatar
At my parking lot of 4 small building and 70 cars in parking only 5 cats are stolen. 4 Hondas and one Acura. Actually as is per internet most valuable is Toyota Prius than all sorts of Hondas. Than at close 3th F250. Yeah F250 is my another car and it has 4 cats all together.
Old Nov 14, 2020 | 09:53 AM
UA5_6MT's Avatar
Save the Manuals
its sad when you have to worry about someone stealing your damn catalytic converter these days
Old Nov 14, 2020 | 10:07 AM
dopeboy1's Avatar
The inconvenient truth
Dang I have my stock jpipe with 3rd cat and pre cats in storage. Wonder what they are worth.
Old Nov 14, 2020 | 10:14 AM
bbsitum's Avatar
I'm moving from here in a few months. But do not want apartments any more. Probably will buy a mobile home. We get enriched here in last 10 years and at top beautiful Mpls city limit is just 1000 feet away. They do not have policing any more.
Old Nov 22, 2020 | 04:38 PM
bbsitum's Avatar
Fixed. If before was 100% sound seal, now is 95% and it is because didn't use any muffler cement in joints for experiment than only nickel anti seize. Can go over winter so and if would like I can always reinstall band clamps with some seal in.
First I bought original replacement cat because universal would not have oxygen sensor bung I guess. Pipes at new cat are 2" OD. Front of exhaust is 2 5/8 OD and rear is 2 1/8 OD. So bought adapter 2" ID to 2 5/8 OD for front. Adapter need not only for pipe size than because hole is 20" and new cat only 17". At back is so called stepped band clamp. 2" ID to 2 1/8 ID.
Gave it to exhaust shop to weld adapter and cut flanges. See how small spacing is from cat to flange, only welding would work. Said to worker there all together should be 19 5/8. All done for 50$. I painted some part of cat with CGC.
Done
Finally have 2 cars again. It was to much to drive my pickup all times.
Old Nov 22, 2020 | 05:36 PM
Nice!
Just watch out for and don't hit any 'road gators' on the highway.
Old Nov 22, 2020 | 07:04 PM
bbsitum's Avatar
^^^ Yours number for oxygen sensor helped me order right one.
Bosal said not muffler cement before cat
Quick tip #4:
Fitting paste must not be used on catalytic converters or any part fitted in front of a catalytic converter; this includes down pipes that are fitted separate to the catalytic converter. Any fitting paste that gets into a catalytic converter will contaminate (poison) the monolith and cause it to heat up so severely to the point where meltdown may occur.
Old Nov 22, 2020 | 09:37 PM
bbsitum's Avatar
Did drive around for 30 miles or so. Exhaust is good as it get right now.
Old Nov 23, 2020 | 10:26 AM
whitetiger5's Avatar
Just my , I'd readjust the clocked position of the converter such that the O2 sensor is coming out less than 90 degress from vertical.
May be the angles in the picture but it seems to be hanging down quite a bit..
Old Nov 23, 2020 | 03:14 PM
bbsitum's Avatar
^^^ Why is that important?
Old Nov 23, 2020 | 03:38 PM
If you drive up quick and hit one of these by accident you may have issues.
It's peak 'road gator' season — and these threats can take bite out of your vehicle - News - The Columbus Dispatch - Columbus, OH
Old Nov 23, 2020 | 03:41 PM
Arkady's Avatar
I'd say just install a cow scoop on the front like they have on old trains - should get those road gators right out of the way.
Old Nov 23, 2020 | 03:48 PM
bbsitum's Avatar
Something about water collecting. Can fix it.
Old Nov 23, 2020 | 04:07 PM
Looks like there is a few reasons, although mine was primarily for those "gators;" if I see an object in the road I think I could drive over rather than swerve to avoid I will take that route. If I had the o2 sensor cable like that, I would be afraid to drive over anything without risking that it would get yanked.
Thankfully, the cat's not welded to the remaining exhaust pipe.
Old Nov 23, 2020 | 04:32 PM
Look at the O2 sensor orientation of the CL-S cat on the video below starting at time 3:45.
Its location looks to be at the horizontal or just a bit above.
Old Feb 17, 2021 | 09:56 AM
bbsitum's Avatar
I think I installed that cat wrong direction as that shield that is up now should be down and it would yield oxygen sensor slightly be up. However I do not drive at rocks so I can live as is. Should that shield be up or down? However it would yield problem when cut flanges would not have enough pipe downstream at cat to clamp to would have to pay welding of something there to.
Well thinking farther 5 minutes in my life now I think it is actually heat shield, not rock shield so I did installed it properly.
Old Feb 17, 2021 | 10:30 AM
bbsitum's Avatar
In that video in #30 obviously short pipe is in front of cat. If is same for my cat it would direct shield up as Oxygen sensor need to be at passenger side.
Old Oct 31, 2021 | 10:14 AM
bbsitum's Avatar
One year latter everything is fine with new cat. No noise and band clamps work, like always they do. Only new cat tends to rust at welds but I'm getting care of it with spraying Cold galvanizing over it 2 times per year.
Old Mar 14, 2022 | 11:25 AM
mmcguire3's Avatar
This just happened to me. Can you share which cat you went with and where you bought it?
Old Mar 14, 2022 | 06:16 PM
bbsitum's Avatar
It is from internet. Do not know where. Just google "acura tl 2003 cat". And than follow directions in #20. Very simple job. Use band clamps. Tape what is gap that exist and - 1/2" for yours cat with adapter(s).
Amazon Amazon
It should be it. Now is 130$, still ok.
Old Mar 31, 2022 | 12:18 AM
Crimsonlies78's Avatar
3rd Gear
I feel your pain OP. Mine was stolen a couple of months ago. They took most of underneath. Thankfully I had full coverage insurance. It took 6 weeks in the shop and they had to put a straight pipe. Sucked balls.
DKraky
3G RDX (2019+)
18
Nov 11, 2020 03:12 PM
youngyaper
Jan 31, 2008 02:21 PM
EL19
Sep 10, 2007 08:59 AM
2CLean
Sep 8, 2007 06:07 AM
cue
Sep 20, 2003 12:01 AM
