Broke Oil Pan!!
Broke Oil Pan!!
I started off by tightening my xs headers, got them all lined up niceley....and when i was about to jack up the car to remove the stands...my godamn car moves fowards and falls on the jack. I looked up and didnt see any damage...and took the car for a 2 minute drive. At the stop light there was smoke coming out and when i drove home there was a line of oil down the whole street.
So pretty much I fucked up, and punctured a whole into my oil pan. I gota buy a new one and was wondering if i also need a new gasket.
yes!! you always replace a gasket with the oil pan.
Others have found good results on a temp repair- (several months)
using JB weld- 2 part liquid epoxy you mix and apply, or in the putty form, 2 part epoxy you can mold/form and press into the crack if its not too bad.
Check other recent thread on same issue
WNC Real Estate Sales99TL
He was a smart man!
6G TLX-S
Did you not apply the rear parking brakes ?
the blocking a tire bit is smart advice
Always block the opposite side and end of the car- so the weight transfer will not
roll the car off the stand or jack
Blocks are far better than park brakes!!
When you do the rear brake job you will understand
IBankMouse
06-13-2020 12:53 PM
xsilverhawkx
09-28-2015 06:51 PM
