BRAKE light turns on
Old Oct 1, 2008 | 09:19 AM
geepers257's Avatar
4th Gear
The other day the BRAKE light comes on a few seconds after I press the brakes and shuts off after released. This happens when I apply the braked when driving and when parked. The light I am referring to is next to the seat belt light in the dash, same one as the e-brake when applied. Does this mean I need new brakes or a light bulb is out? The strange thing is that this was only happening for a day. The next morning and till now the light has not turned back on when I press the brakes. What are your suggestions? Thanks.
Old Oct 1, 2008 | 10:09 AM
fog80's Avatar
i have a similar problem my brake light stays on as if my e brake is on but i never use my ebrake.
and then some days the light will just go away and some days it will stay on all the time.
Old Oct 1, 2008 | 01:29 PM
totaledTL's Avatar
Check obvious/easy things first. Brake fluid level, emerg. brake (pedal) switch.
Old Oct 1, 2008 | 01:37 PM
FirePR2002's Avatar
bringin lead
the OP's problem sounds like low fluid level. if not, clean the master cylinder cap and wires with a rag to see if it solves the problem.
Old Oct 1, 2008 | 03:04 PM
01tl4tl's Avatar
agree with fire --got to check for low fluid level- that sliding thing on the inside of the cap.. is to send a message when fluid is needed!
WHEN the brake pads get low- and realllly low- more fluid has to fill the caliper, so it goes from the master cylinder and makes the signal trigger
When you push the brakes, a small amount of brake fluid moves towards the brake calipers to operate them- lowering the level further in the master.
Check the brakes and see what the real pad condition is if the res is low
Old Oct 2, 2008 | 10:58 AM
geepers257's Avatar
4th Gear
i will check the fluid and clean the master cylinder cap tonight and hopefully that solves the issue. the back brakes seem like theres more than enough meat on the pads. the front, i couldnt really see the pads due the larger size of the caliper coving up the pad but will try to check again. thank you all and i will let u know the out come of this mysterious light.
Old Oct 2, 2008 | 01:01 PM
fsttyms1's Avatar
fluid level or the float on the brake cap is hanging. TOp off with new fluid and clean the float and cap
Old Oct 4, 2008 | 12:26 PM
CL-Slick's Avatar
Chillin' in my trailer
I started a thread exactly like this in the 2ng Gen CL forum. Go check it out. I fixed my light.
Old Oct 6, 2008 | 09:46 AM
geepers257's Avatar
4th Gear
i checked the brakes, still a lot of meat left and i cleaned the brake cap friday...so far the light has not came back on since. hopfully it stays that way and thank you all for you help.
Old Oct 6, 2008 | 11:06 AM
FirePR2002's Avatar
bringin lead
no problem, that's what this site is all about....
Old Oct 6, 2008 | 11:24 PM
Gfaze's Avatar
S E L L
mada51589
Jan 9, 2025 04:40 PM
PortlandRL
Sep 14, 2015 12:01 PM
HOWELLiNC
Sep 10, 2015 01:39 PM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
ptbarnett
3G RLX (2013+)
Aug 30, 2015 12:39 PM
