Brake Light
Brake Light
The past few weeks my Brake light has been dimmed (sometimes I can barely see it, sometimes its a little brighter) when driving. When I use the e-brake then it is bright red (Like its suppose to be). When i let go then it is dimmed. I just checked the light bulb and switched it when another one and it does the same thing. Whats going on with my Brake light??
brake light is a warning light for the system
brake LAMP is bulb problem
ck the fluid level in brake master cyl- should be very close to the top--to the neck
If low- have brakes checked
Ck the slider sensor inside the res cap, does it move freely?
How does the fluid look? ever change the brake fluid?
Are the brakes holding solid at a stop or does the pedal go down to the floor
Lately , my brake lamp in dash start to light up sometime .
Did check the fluid is OK ...Suspect the sensor in Res. Cap .
Do anyone know how the sensor works ? I see some fluid inside the sensor cyl.
It's normal to have fluid inside the tube ?
mada51589
Jan 9, 2025 04:40 PM
rockyboy
Aug 4, 2024 10:35 AM
Ny1718
Sep 11, 2015 09:21 AM
