Brake Light
Old Sep 4, 2010 | 10:14 AM
patx919's Avatar
Brake Light
The past few weeks my Brake light has been dimmed (sometimes I can barely see it, sometimes its a little brighter) when driving. When I use the e-brake then it is bright red (Like its suppose to be). When i let go then it is dimmed. I just checked the light bulb and switched it when another one and it does the same thing. Whats going on with my Brake light??
Old Sep 4, 2010 | 10:28 AM
01tl4tl's Avatar
brake light is a warning light for the system
brake LAMP is bulb problem
ck the fluid level in brake master cyl- should be very close to the top--to the neck
If low- have brakes checked
Ck the slider sensor inside the res cap, does it move freely?
How does the fluid look? ever change the brake fluid?
Are the brakes holding solid at a stop or does the pedal go down to the floor
Old Sep 5, 2010 | 07:34 PM
totaledTL's Avatar
Check the switch for the emergency brake- may need to be adjusted.
Old Sep 6, 2010 | 12:16 AM
01tl4tl's Avatar
would that make it come on dim then bright?
note- due to lawyers, it no longer called an `Emergency Brake`
its only a Parking brake,,and not much of one at that--just mini drum brakes inside the rear rotor
Old Sep 6, 2010 | 12:17 AM
01tl4tl's Avatar
could just need a new cap if its level sensor is dieing =$35
Old Sep 9, 2010 | 01:24 PM
acurabum's Avatar
Lately , my brake lamp in dash start to light up sometime .
Did check the fluid is OK ...Suspect the sensor in Res. Cap .
Do anyone know how the sensor works ? I see some fluid inside the sensor cyl.
It's normal to have fluid inside the tube ?
mada51589
Jan 9, 2025 04:40 PM
rockyboy
Aug 4, 2024 10:35 AM
Ny1718
Sep 11, 2015 09:21 AM
HOWELLiNC
Sep 10, 2015 01:39 PM
mav888
1G RDX (2007-2012)
Sep 8, 2015 11:49 AM
