99TL DASH LiGhTs DoNt WoRk
Old Sep 19, 2005 | 07:00 PM
BiggggyBMF's Avatar
7th Gear
Hey, i dont know if anyone can help me out but my speedometer, gas and rpm meter light all do not work. I got the car used and didnt get an owner manual and have looked at the fuses but dont know which one or number it could be. If anyone could help me out or tell me what is wrong or they think is wrong that would be great!!
Old Sep 20, 2005 | 10:19 PM
joseph_99tl's Avatar
there's a driver and passenger side fuse box.
if that helps.
but this sounds odd.
Old Sep 20, 2005 | 11:57 PM
check the dimmer switch located on the lower left of the dash.
If that did not work,
Check the fuse and then make sure the dimmer switch wire is connected correctly.
Old Sep 21, 2005 | 12:00 AM
aaronnn's Avatar
when you open the passenger side door, by the glove box, you will see a Fuse panel. pull that panel off and on the back side, there will be a list of interior lighting sections. find the one that controls the dash (im not sure which one, but i think you'll know when you see it). use a small plyer and pull that specific fuse out.
now go look under your hood. look all the way to the back when standing in front of your car to the passneger side. you'll see a black fuse box with a little diagran of fuses. look for the one that reads "spare". take that spare fuse out and replace it with the one you took out in the passenger side.
put all the covers and panels back on, hit the light switch and it should light up.
if not then that means your bulbs from behind the odometer are blown, which could be the case because you have a 99tl.. which means its been 7 years since they have been put in.
Old Sep 21, 2005 | 12:37 AM
yunginTL's Avatar
trill recognize trill
...haha....
Old Sep 21, 2005 | 08:07 AM
[QUOTE=yunginTL]99TL DASH LiGhTs DoNt WoRk
mada51589
Jan 9, 2025 04:40 PM
Soul_Deamon
4G TL Problems & Fixes
Nov 2, 2015 04:32 PM
acurajj
Sep 19, 2015 03:47 PM
Birdflunuggetz
ILX
Sep 14, 2015 07:00 AM
theinsvnity
Sep 10, 2015 10:22 PM
