2016 ILX computer issue?
Old Sep 7, 2015 | 09:27 PM
Birdflunuggetz's Avatar
Several times now, I have started my car and the following items occur:
  • Radio station memory deleted (station pre-sets still work, but the numbers do not show on the bottom screen of the dash...show wrong stations even though the correct station is playing when on FM, when on SXM the pre-sets are merely blank)
  • Auto-on lights stay on even in bright sunlight
Thing is, when this happens, I can usually just kill the car, then re-start it, and all is good...the lights go off, as they should, and the station displays on the bottom screen show correctly.
Wondering if anyone else has experienced this one. Thanks in advance.
Old Sep 8, 2015 | 09:29 AM
Steven Vitek's Avatar
16 SSM ILX Prem-Aspec
just took my car in for its first oil change and mentioned the same problem with my radio display, its random so i hope they can reproduce, will let you know
Steve
Old Sep 8, 2015 | 10:17 AM
Waldo87's Avatar
I've had the same issue with my stereo when I first got my car. It happened about 2-3 times, but it hasn't happened in quite a while (knock on wood).
Old Sep 8, 2015 | 10:22 PM
Well, while they are waiting for my replacement rotors to arrive, they are going to do a "hard reset" on my computer...guessing I will have to re-program everything once I get the car back...but at least the problem will not arise again (hopefully).
Old Sep 9, 2015 | 07:17 AM
Had my car in for service and mentioned the computer problem, they could not reproduce the problem but reset my computer, did not loose my presets...
Old Sep 9, 2015 | 04:59 PM
Nice to know, thanks!
Old Sep 9, 2015 | 08:47 PM
vanderveen44's Avatar
What does it entail
Do you know what the hard reset entailed? Can that be done easily by myself at home?
Old Sep 10, 2015 | 07:27 AM
not sure, i can ask when i take it for the brakes, i am sure someone here know the procedure
Old Sep 10, 2015 | 07:42 AM
Thanks that would be great. Also were you breaks making noise or did you just get new rotors as a preventive measure?
Old Sep 10, 2015 | 08:41 AM
They were squeaking, but i think the directive is to inspect and replace the brake rotors for any rotor manufactured before 05.27.15
Old Sep 10, 2015 | 09:54 AM
Steve...did you also experience scratching of the clear window that goes over D, R, N? If so did you have Acura repair it or did you try to polish it
Old Sep 10, 2015 | 01:18 PM
Waldo87's Avatar
Mines a little scratched up, but I didn't want to stress over it so I just ignore it.
Old Sep 10, 2015 | 02:34 PM
Yes mine is also scratched, but since i didnt bring it up to the dealer from the beginning I didnt bother asking, it bugs me everytime i look down and the light catches it, i have some plastic polish at home i will try tonight
Old Sep 14, 2015 | 07:00 AM
Waldo87's Avatar
Well... new issue arose this morning with my stereo. It would connect to my phone via Bluetooth for like 2 seconds and dropped out and it repeated this during my entire drive to work. I pulled over and turned the car off and back on and the problem proceeded... so then I turned off the Bluetooth on my phone and turned it back on and had the same problem. We'll see what happens on my drive home and if the problem continues, I guess it's time to finally take it to the dealer and have them take a look at my brakes while it's in there.
jriv7
May 8, 2020 05:50 PM
SpraykwoN
ILX
Sep 23, 2015 11:44 AM
Steven Vitek
ILX
Sep 10, 2015 07:29 AM
Drake3287
ILX
Sep 9, 2015 11:21 AM
