5 codes read after the VSA, ABS, and exclimation light
Old Sep 9, 2009 | 03:21 PM
FlacoJ's Avatar
these codes poped up onto a snap on reader 25-01 yaw route sensor malfunction , 51-01 abs pump motor malfunction, 53-01 ABS pump motor relay short circut,
VSA codes72-01 modulator unit malfunction and8301- ECM/PCM relation malfunction
I checked and cleaned the rear wheel sensor, the lights turned off later that day at random but that good fortune was short lived. now these lights are always on
25 tls solenoid, 53 motor stuck on, 83 pgm-fi communication this is an 02 TL-S can anybody help??
Old Mar 31, 2011 | 01:22 AM
blurrpleberry's Avatar
53 gonna figure out soon
Old Mar 31, 2011 | 01:27 AM
01tl4tl's Avatar
another dead thread revival from 2009!!
what were you searching for blurr? got a car problem?
Old Apr 4, 2011 | 09:24 AM
yep got a 53-1 abs/vsa code atleast thats wut my honda mechanic told me. abs light on vsa and ! triangle lights all on constantly
Old Apr 4, 2011 | 09:39 AM
01tl4tl's Avatar
your avatar shows lowered car--if thats you, its possible 1 or more speed sensor wires at the wheels have been damaged,,it happens~ often to a front where wire gets corroded or caliper gets hung loose instead of secured up with a wire tie when working on brakes,,,
have you tried an ecu reset by `clock fuse removal method` and see what happens?
A brake shop will have the special reader for ABS codes and troubleshooting
that normal readers wont get
what work was done on it last?
Old Apr 8, 2011 | 09:10 AM
just 4th gear clutch switch replaced and ignition switch. wheel rotations oil changes.
Old Apr 8, 2011 | 11:10 AM
01tl4tl's Avatar
its always possible a wire to speed sensor got damaged in wheel rotation,,or general mystery damage
reset ECU as described before with clock fuse and see what it does
your mechanic made no guess as to cause of lights- besides reading codes which we all know are- lets say it together- CLUES!!!- not Diagnosis on their own.
false codes lead to real problem
Old Apr 8, 2011 | 11:20 AM
my mechanic was short on time because i had to go on work and gave me the code to search up on here to see wut i could figure out. its so crazy on how many parts from different years and models of hondas are put in the 2g tl. he had to keep going back and forth in the books and ran out of time
Old May 18, 2011 | 11:21 AM
t3h hott!'s Avatar
4th Gear
Hey have any of you guys figure out anything on the problem you're having? My 03 tl-s has these 3 lights on and I got the codes read at acura, the are telling me its giving a couple codes but the most definite is right side wheel sensor... but then they tell me this car has a sensor inside the wheel hub basically where the wheel bearing is... never heard of that.
Old May 18, 2011 | 01:45 PM
01tl4tl's Avatar
ask to speak with the service manager if the writer didnt do their job explaining needed repairs
'03 is different than my 01, but if a wheel speed sensor is bad- you replace it!
Go to another place that specializes in brakes and get a 2nd opinion
Old May 18, 2011 | 07:54 PM
Karanx7's Avatar
Unregistered Member
FlacoJ, I apologize. I wasn't around to respond to your post for help. It seems you had some shitdeep problems, and no one helped you =[
Old May 18, 2011 | 08:04 PM
hANDYcaptd's Avatar
It's the Halladay season!
That was 2 yrs ago. Pretty sure he's moved on...
Old May 18, 2011 | 11:39 PM
JterrorC's Avatar
Always a Honda =Þ
umm.... this reminds...i have NOO ABS.. never did never cared... until i had to stop short for a light....n car locked up n just slid on by stopped at the cross walk.... but at the time i wasnt loggin on as much so i just forgot til i seen this post...i have no check engine light nor abs light... abs bulb out mayb?... how do i read the codes?
Old May 19, 2011 | 07:44 AM
fsttyms1's Avatar
Replace the wheel speed sensor and have the code reset to see if its the problem. Wheel speed sensors are usually the culprit in these cases.
Old May 19, 2011 | 09:32 AM
FlacoJ's Avatar
I replaced the abs relay under the hood, and the abs works about 30 percent of the time
, which isn't bad
Old May 19, 2011 | 11:00 AM
01tl4tl's Avatar
how often are you calling upon the ABS anyway??
what do you mean 1/3 of the time..every 3rd time you stop is a full on max effort slick conditions?...or your bad speed sensor is causing it to abs in normal traction conditions?
It should only come on in wet/slippery conditions where you break traction on one or more wheels
as on: hit ice, see stopped car in front of you- slam brakes ~panic stlye~ AND crank the steering wheel to avoid the accident ahead of you
Neatly drive around the crash without being a part of it!
If your abs is pulsing the pedal in normal conditions: look to speed sensors- bad wire and dirty ring
Old Jul 25, 2011 | 02:00 PM
anyone fix 53-1 yet? havent had time or money
Old Jan 24, 2012 | 12:54 PM
, which isn't bad
I did the same. And got the same results. Just havent had time to get the speed sensors replaced. I need to go in for a recall on airbag replacement and will have them checkout the speed sensors then.
Old Jan 17, 2013 | 03:59 PM
, which isn't bad
I did the same thing. does anyone have a picture of a wheel speed sensor so i know what i am looking for. preferebly on the car and not separate. p.s. comptech headers finally installed w/ tein springs and eibach struts!
Old Jan 17, 2013 | 04:06 PM
also what is a TSB?
Old Jan 18, 2013 | 07:59 AM
fsttyms1's Avatar
Go take your wheel off and look at the back side of the knuckle (behind the rotor) there is a wire that comes down the knuckle and goes into it and reads the pickup teeth on the axle. Its the only wire that runs down there.
Old Jan 18, 2013 | 08:01 AM
fsttyms1's Avatar
also what is a TSB?
Technical Service Bulletin. It is a known repair for a specific model of car/truck reported in detail by the manufacturer.
mada51589
Jan 9, 2025 04:40 PM
cycdaniel
Dec 17, 2019 10:58 AM
gemz_acura
4G TL Problems & Fixes
15
Sep 26, 2015 06:12 PM
bryan zaragoza
Sep 8, 2015 12:28 AM
Stu2414
Aug 30, 2015 07:30 PM
