3rd and 4th gear pressure switch
Old Jun 27, 2024 | 11:57 PM
dreweyebarra818's Avatar
WDP ‘03 TL-S
Was having the usual tranny problems(blinking d, going into safe mode, and p0780, p0740,) I first did the external filter change. And the 3x3 using demitsu fluid. Then I forget the exact code but it gave me the code for the bigger solenoid with 2 connectors and the 3 filters that get clogged i believe it is called the an and b transmission solenoid. So I switched that out. Singles out my problem to be from 2-3 and 3-2 so I decided to switch out both of these switches and my tranny has miraculously came back to life. Who knows for how long and how long it will be before I do the av6 swap considering I have a heavy foot and if this tranny can’t take it, it’s gotta go lol.
here’s a video I made if it can be of any use to anyone go on ahead
https://youtu.be/Vlpsmrcf9w4?si=OfreO0X8vfmJHNEj
Old Jun 28, 2024 | 02:52 AM
Nice job & thanks for the video!
However, if you purchased those two switches, with the Honda branding shown on the video, online for $30 usd the probability is high that they are most likely aftermarket non-OEM.
Hopefully they give you & the transmission long life utility, though on the other hand, don't be surprised if one or both fail in a short period of time.
Amazon.com: Transmission Pressure Switch,2 Pcs Transmission Pressure Switch for Honda 28600-P7W-003 28600-P7Z-003 : Automotive Amazon.com: Transmission Pressure Switch,2 Pcs Transmission Pressure Switch for Honda 28600-P7W-003 28600-P7Z-003 : Automotive
In addition, the OEM website below has the #13; 3rd gear black 28610-RKE-004 as the superseded replacement for 28600-P7Z-003 shown on the video.
You can also see that the original factory switches removed utilized a 90471-PW7-A00 aluminum 10mm gasket versus an o-ring.
Not sure if that matters, though when I replaced mine (CL-S) they (each switch) had two 90471-PW7-A00's because the tranny rebuilder (from previous owner) reused the old switches and mistakenly put on another 90471-PW7-A00 each .
5AT Sensor - Solenoid - 2003 Acura TL 4 Door TYPE-S KA 5AT (acurapartswarehouse.com)
As you mention, the only real long term remedy for these glass transmissions is the AV6 swap.
2004TL1974
Aug 6, 2019 07:32 PM
jff468
Apr 19, 2015 06:42 PM
2doe
1G TL Problems & Fixes
15
Jan 28, 2013 06:11 PM
06TLBLACK
Jun 15, 2011 04:00 PM
crussell710
Mar 29, 2011 08:55 PM
