tranny codes (obd2)
Old Mar 24, 2015 | 04:52 PM
jff468's Avatar
7th Gear
tranny codes (obd2)
Hey guys. I keep getting a CEL on my 99 tl. The code is P1738. No one a the parts store could tell me what the code meant. It just said refer to manual, which I don't have. I know it deals with the transmission but what exactly does it hint towards? TIA
Old Mar 24, 2015 | 05:46 PM
Dabu's Avatar
https://acurazine.com/forums/problem...0401-a-810924/
Old Mar 24, 2015 | 06:11 PM
musiclevelz5's Avatar
I opened the link and it says its the 2nd clutch pressure switch which sounds about right.
You can get a pressure switch from Amazon for like 30 bucks and install it yourself. Its easy.
Just have to jack the car up a bit and take the driver wheel off. I replaced mine and it took maybe 20 minutes.
Old Mar 25, 2015 | 11:22 PM
ErickUa5's Avatar
Mr.Helpful Diagram
Sorry to say but thats the code of death, Heres some test you can do:
1:Check ATF level : On level surface engine warmed up and off. If ok next
2:Test 2nd Gear pressure switch : the switch sends a ground (-) to the ECU, if the ECU does not see the ground then it will set a code. What causes that? No or not enough oil pressure to 2nd gear, broken wire or damaged switch.
Does it shift into 2nd gear ? if so is it harsh or takes long to engage.
Things to try before replacing the transmission:
Replace 2nd gear switch.
Try a drain and fill with 3 quarts of Honda ATF DW1 3 times to replace the majority of the old fluid. (3x3)
Old Apr 19, 2015 | 06:42 PM
jff468's Avatar
7th Gear
It still runs and shifts fine but its throwing the codes. It may just be time for the switch replacement
TypeS860
Jan 10, 2026 11:11 AM
Jamus22
Jun 11, 2023 10:08 AM
xsilverhawkx
Oct 5, 2015 11:00 AM
thegipper
Sep 28, 2015 01:01 PM
shawnafoxx
1G RL (1996-2004)
Sep 28, 2015 12:33 PM
