02 Acura TL HID bulb question (quick help plz)
Does anyone know what kind of bulb the 02 acura tl has? My passenger side bulb has been out for awhile and I really need to replace it. The dealership wouldn't give me any info on the bulb and said it was just an HID. They gave me an estimate of $150 + 55 installation. I really would like to just buy the same one online and install it myself. Any help tips would be appreciated. Thanks in advance!
Btw, they also gave me a recall letter for my airbag and said there's a possibility of a shrapnel bomb explosion. I'm assuming most of you guys had it replaced already?
Low Beam Headlight Bulb Size: HID-D2R
High Beam Headlamp Light Bulb Size: 9005
Parking Light Bulb Size: 1157A
Front Turn Signal Light Bulb Size: 1157A
Rear Turn Signal Light Bulb Size: 1156A
Tail Light Bulb Size: 7443
Stop Light Bulb Size: 7443
High Mount Stop Light Bulb Size: 7440
Fog/Driving Light Bulb Size: 9006
License Plate Light Bulb Size: 168
Back Up Light Bulb Size: 921
Front Side Marker Light Bulb Size: 168
Map Light Bulb Size: 168
Dome Light Bulb Size: DE3175
Step/Courtesy Light Bulb Size: 158
Trunk/Cargo Area Light Bulb Size: 168
So I changed my passenger side bulb with no problems, but now it will not turn on. Can anyone help me out with this? I can't afford to take it to the shop right now.
All the other lights work on my car besides the passenger low beam.
please try looking thru the `problem and fixes` thread section
or the diy or search for headlights
do you have moisture inside the housing lens after washing, or overnight mositure gets into there?
if so- that water drips down and out a vent hole directly above the ballast and that fails- plenty of horror stories about it- just have a look
aftermarket ballest or auto recycler (junkyard) for replacement
tman570
Jun 11, 2019 07:56 AM
wusty23jd
Sep 24, 2015 11:41 AM
