Power Steering question
Old Jun 6, 2010 | 05:57 PM
032TLS's Avatar
is it normal to hear the powersteering from inside the car i never heard it before and i noticed that the fluid was low so i toped it up but now its low again i searched for leaks bur couldn't find any. Anyone know what the deal is or had this problem?
Old Jun 6, 2010 | 07:19 PM
01tl4tl's Avatar
you have a leak- find it
look at back of ps pump for leak at orings and feel the hoses and hose ends for fluid
ck rubber end caps on steering rack- peel back and look for fluid- should be none there or rack seals have blown
Have friend turn wheels back and forth with engine running so you can observe under load
Old Jun 6, 2010 | 07:20 PM
01tl4tl's Avatar
if you hear the steering inside the car the pump is whining- from bad bearing or low flud (which leads to bad bearing)
try a search on here for `steering pump` in the prob and fixes section
Old Jun 6, 2010 | 10:17 PM
hANDYcaptd's Avatar
It's the Halladay season!
I would get this fixed ASAP. The PS pump is just waiting to fail.
Find the leak, it's probably a very slow one. Check for built up dirt and grime, it where the fluid probably leaks.
Old Jun 6, 2010 | 10:38 PM
032TLS's Avatar
Alright i'll get on this tomorrow thx guys
Old Jun 7, 2010 | 06:00 PM
032TLS's Avatar
Ok so I found the leak it's on the drivers side I don't know what it's call but it connects to the firewall and the tie rod connects to it it's leaking at the to will this be a big job to fix?
Old Jun 7, 2010 | 08:15 PM
Hot Boi's Avatar
Grippin' Grain
I thought the PS was in the passngr side.
Old Jun 7, 2010 | 08:22 PM
032TLS's Avatar
the pump is on the passenger side. I just found out what this thing is called its the steering rack its leaking at the top is there a seal there that i could just change or do i have to change the hole thing?
Old Jun 8, 2010 | 09:25 PM
032TLS's Avatar
can i just change the boots or do i need to change the hole rack
Old Jun 8, 2010 | 09:30 PM
032TLS's Avatar
If the pics don't show up heres the link
http://img190.imageshack.us/g/img0213ub.jpg/
TL-Rocket
Apr 29, 2023 02:33 AM
Yikes
May 3, 2021 04:29 PM
mike from annapolis
May 7, 2017 08:21 PM
nash3222
Sep 10, 2015 09:46 PM
