Installing puddle lights
Old Jan 14, 2012 | 03:50 AM
aznccnsh's Avatar
I don't see much people having the puddle lights on our 2g tl. So I dont know which wire to tap into in the fuse box that turns on and off with the key fob.
The 3g guys have this write up that makes so much sense https://acurazine.com/forums/3g-tl-2004-2008-93/puddle-light-wiring-up-schematics-detailed-pics-835659/, but my fuse box doesnt look as similar so i cant compare.
Can anyone help me to find the wire that I need to tap into. thank you.
Old Jan 14, 2012 | 09:22 AM
tOny3's Avatar
In the 2G tl there is no dome supervision wire, instead you can tap into the Door trigger wire which is located on top of passenger fuse box, its a black/white (-) wire in a 4 green pin plug.
Took it from that 3G thread...
Old Jan 14, 2012 | 11:12 AM
jjashaa's Avatar
Avant Garde Wheels
its actually white/blue from what i remember.
Old Jan 14, 2012 | 11:39 AM
aznccnsh's Avatar
And the positivie wire in run from the battery right? I looked at the led door handle in the diy section and it sounds like same idea I wanna do. Wouldn't it be the same wiring
Old Jan 14, 2012 | 01:19 PM
jjashaa's Avatar
Avant Garde Wheels
Black wire w/ white stripe and 2 silver repeating marks (NEGATIVE)
White wire w/ blue stripe and 2 silver repeating marks (POSITIVE)
if you look at pass fuse panel.
there is a green plug that is 4 pin ( 4 wires )
look for that
tap into that.
Old Jan 14, 2012 | 01:58 PM
aznccnsh's Avatar
And was it hard for you to position the lights? Mine seems to be hard. U did the drill in skirt method right? Maybe cuz I got stock skirts?
Old Jan 14, 2012 | 05:03 PM
aznccnsh's Avatar
I know the positive wire is the white and blue, but when i stick the negative to the black wire with white stripes it just wont turn on. But If i just stick the positive in and put the negative on a ground metal piece it just turns on forever. ugh
Old Jan 14, 2012 | 10:05 PM
jjashaa's Avatar
Avant Garde Wheels
yea. so. connect the neg to black wire.
then try turning on your domes.
as for the ground. i wired a 3 way switch.
completely off, Neg was connected to nothing
always on, neg was connected to ground
connected to dome, neg was connected to wire on pass fuse.
Feb 25, 2020 09:57 AM
cycdaniel
Dec 17, 2019 10:58 AM
Marmbo
4G TL Problems & Fixes
Sep 21, 2015 09:39 AM
Nicho863
Sep 2, 2015 08:12 AM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
