how do you install a cold air intake
Old Aug 2, 2010 | 08:41 PM
03blueTLtype-s's Avatar
So I installed my injen cold air intake and it said I had too remove a coolant hose and idk I got confused so can u guys post pics of ur cai setup
Old Aug 2, 2010 | 09:00 PM
assclown's Avatar
2000 acura tl FPR
that's one of the best ones i could get.
i know what you are talking about, i was stuck for a bit when i was doing mine, their instructions aren't the best. but you have to disconnect the pvc pipe and connect the breather hose (injen supplied) and then you couple the two hoses together with the white coupler supplied by injen. pretty easy, but instructions are misleading.
Old Aug 2, 2010 | 09:29 PM
fsttyms1's Avatar
2 possible things being talked about.
1.) the 99 had a mini radiator in the intake that needed to bypass. If you dont have a 99 skip that step.
2.) the throttle body coolant hose. Bypassing that will make the TB cooler. Take the coolant hoses off the TB and connect them together. (cant see them with the engine cover on.
Old Sep 8, 2010 | 11:21 AM
99_AcTl's Avatar
6th Gear
I am trying to install a new intake on my 99 TL what should i do about that mini radiator in order to bypass it? the intake will not fit with that setup in place.
Old Sep 8, 2010 | 02:11 PM
tc5280's Avatar
Flagship Aspec
I think it looks better hidden as much as possible
Old Sep 8, 2010 | 11:38 PM
99_AcTl's Avatar
6th Gear
here are a couple pictures of the setup...I do not know what to do with the hoses
please help!
Old Sep 8, 2010 | 11:51 PM
99_AcTl's Avatar
6th Gear
sorry for the broken links here are the pictures
?action=view&current=intake_2.jpg#!oZZ2QQcurrentZZhttp%3A%2F%2Fs1217.photobucket.com.jpg%26
Old Sep 8, 2010 | 11:53 PM
99_AcTl's Avatar
6th Gear
http://s1217.photobucket.com/albums/...2.jpg&newest=1
Old Sep 14, 2010 | 03:44 PM
Machine17's Avatar
6th Gear
How different is it to install the Injen CAI in a 2007 Type S TL??
Old Sep 14, 2010 | 04:31 PM
assclown's Avatar
2000 acura tl FPR
Old Oct 5, 2010 | 01:46 PM
aznccnsh's Avatar
So when I take out the large hose and replace it with the injen 20" injen hose, the smaller hose that went along with the larger one goes where? The directions say to just remove it, do I really just remove it? And what 2 lines are connected by the 1/4" coupler, I dont understand that one.
Old Nov 2, 2010 | 07:40 PM
JakeType-S's Avatar
8th Gear
Reroute the hose to the back side of the engine and then you will have enough slack for the coupler. You should have both the metal lines removed completely.
space_boy
ILX
51
Aug 15, 2017 12:06 PM
drone619
Jan 26, 2016 07:09 PM
Mikehxbx
Sep 13, 2015 01:09 PM
theinsvnity
Sep 10, 2015 10:22 PM
dlknight
Sep 3, 2015 07:54 PM
