Catalytic Converter Question
Old Oct 17, 2019 | 11:37 PM
Marsalis Simms's Avatar
UA7_Unknown
I had recently picked up headers with a flex pipe and it appears the cat it came with is gutted. I’ve typically either left the OEM cat on or bought a high flow with previous vehicles, so am curious if running this will throw a code on my TL or if I’m better off just buying a high flow as I originally intended?
Old Oct 18, 2019 | 09:41 AM
UA7_Unknown
Another thing I wanted to add; if it does throw a code presumably for the 2nd O2, it should not impact performance as to my understanding it’s the 1st O2 that measures A/F ration and not the 2nd?
Old Oct 18, 2019 | 10:16 AM
losiglow's Avatar
It will very likely throw a code, P0420, for "catalyst efficiency below threshold". I'm well versed with that dreaded code. And yes, you're correct that it won't affect performance. If anything, it will free up flow and give a few extra horsies. However, the catalytic converter also serves to muffle some of the exhaust noise, so you'll experience a different exhaust tone - louder for sure. But with the resonator and mufflers, it's not likely to be overly droney or raspy.
A fix I recommend if you choose to go with a gutted cat or straight pipe is a defouler, which is more or less a spark plug spacer with the center drilled out. You can look up the method on YouTube. That method works about 75% of the time. Expect the occasional code to pop up though. Better yet, if you want to nearly guarantee no problems, get a "mini" catalytic converter dongle like this one:
Amazon Amazon
I don't condone running without a cat though. But if you choose to do so, those are a couple ways you can do it without getting a CEL popping up.
Old Oct 18, 2019 | 10:42 AM
UA7_Unknown
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Alright, I appreciate all the info. I will look into that Amazon link and most likely get everything hooked up in the next couple of weeks. Thanks again!
Old Oct 18, 2019 | 11:08 AM
I thought I read here, somewhere, that if you are not supercharged or turbocharged a hi flow cat would only hurt your performance being normally aspirated? Something about losing back pressure when running headers.
Old Oct 18, 2019 | 11:28 AM
losiglow's Avatar
The need for back pressure is a myth.
Old Oct 21, 2019 | 05:20 PM
Silencer_'s Avatar
Sup Marsallis! I'm pretty sure it's gonna throw a code. As long as you don't live in California where emissions is extremely strict (ie smog checks), a high-flow cat will be fine!
Old Oct 21, 2019 | 05:42 PM
UA7_Unknown
Much appreciated. I'm actually buying a Magnaflow next week just in case this experimental gutted cat doesn't fit my taste. Thanks again for the input!
Old Oct 21, 2019 | 06:08 PM
Silencer_'s Avatar
I went with a Magnaflow when I failed the smog check lol. Been good to me ever since. Good luck!
Old Nov 21, 2019 | 11:45 AM
UA7_Unknown
Going to buy a replacement CAT as the OEM one was bad regardless and with it gutted I don’t like the sound; don’t feel like messing with mufflers or anything to fix the noise either. What aftermarket CATs do you guys recommend?
Old Nov 21, 2019 | 12:12 PM
Silencer_'s Avatar
I have Magnaflow lol. Passes smog every time (I live in California so emission laws are strict af).
Old Nov 21, 2019 | 12:15 PM
Checkout rockauto, they have an assortment from $119.79 - $256.79.
Old Nov 21, 2019 | 12:38 PM
Don't forget the 5% off code!
https://acurazine.com/forums/sponsor...2020-a-982826/
Old Nov 21, 2019 | 02:50 PM
Yes!
I'm also hoping RockAuto does some kind of Black Friday promotion.
MrG22
Apr 24, 2014 09:19 PM
azeezp13
Jun 20, 2012 08:37 PM
Harrisonk531616
Jul 15, 2010 10:54 PM
Rush330hp
2G CL Problems & Fixes
Apr 21, 2009 04:42 AM
mav3556
25
Dec 17, 2008 12:22 PM
