can you blow an amp during installation?
So I was installing my amp today(Alpine MRP-M650). I installed everything but then when I powered it on...I got no power light and all the fuses are good and power/ground are good too. I dont have the sub hooked up yet as I'll get it tomorrow. I did notice that when i was connecting the power wire to the amp it had a very small spark to it and the gournd wire was not connected ....could that have caused it to blow?
it should be fine. check the fuse under your hood where u connected the power lead to the battery. and make sure where ur ground wire connects to the chassis of the car from the amp is grinded down to bare metal.
dont worry too much about the spark...ive done that plenty of times in my 4 years of audio installation.
illmat1k and wildcat are both right..those are the 2 most likely reasons why youre not getting power.
get a knife and scrape off the paint where the ground is bolted to the chassis.
if thats okay, then double check your remote turn-on wire that goes from your head unit to your amp.
oh and next time just remember to disconnect the negative terminal of your battery so that you dont get any sparks again. it does reset all your head units settings and the cars clock but better safe than sorry. i highly doubt you shorted your amp this time though.
good luck!
good luck!
THUMP THUMP THUMP!!! IT WORKS NOW!!! you guys were right....I wasn't grounded right cause I didnt' shave off the paint...I'm gonna most a picture heavy walk-through soon on getting to the amp in the back of the seat and wiring it to a after market amp.
Thanks so much for everyones help!!!
after a quick search on Google about your specific sub, it appears there is a switch on the sub to select between 1 or 4 ohm, so if i read correctly, youre stuck with either 1 ohm or 4 ohm, to get to 2 ohm, you would have to run 2 subs @ 4ohm and "bridge" them together. its been awhile since i connected things myself, so i cannot get too specific on connections other than what i stated.
mada51589
05-03-2022 08:54 PM
Pegon95
09-15-2015 01:54 PM
