XS header resonance...gone???
Lamborghini Aventador FTW
Well I've had resonance ever since I installed my XS headers. Some days it is a lot, some days it's not as much, but lately it was getting worse in general. Well today I happened to go over a bumpy section of road a little faster than I should have and it jarred the car (I didn't bottom out but it was probably close to it). I drove to my destination (not particularly paying attention to the resonance), and got out of my car for about an hour. After getting back in my car to drive home, I noticed that the resonance was 100% GONE!!! We'll see tomorrow if it's gone for good or if my car was simply playing with my emotions.
I bet something has been loose this whole time and now you temporarily moved what has been loose enough to vibrate and cause resonance. I have the XS Headers and have never had any resonance of any kind at any point. I put them on last fall. My guess is if you hop under the car you'll find some areas that need a bit of tightening.
I have been having insane resonance for the past week. Lifted the car yesterday morning to find my O2 Sensos' threads were eaten up and it was just sitting in the bung
Gonna pick up a new one tomorrow, hopefully the bung's threads arent damaged, or I'm screwed...
Originally Posted by fsttyms1
if you have resonance that usually means something isnt lined up properly. Id loosen the bolts then retighten them.
I'll give that a try. Is there any particular order in which I should tighten things? i.e. first header manifold, then header to down pipe, then down pipe to cat. Or does the order not really matter?
Originally Posted by AMGala
This may be (the rear header bolts were the hardest to tighten) but I did retighten all the bolts 2 weeks after I installed them.
hey hey dont blame the rear headers......you got the finest tightenin them LOL
Former Sponsor
Can overtightening the bolts somehow lead to resonance?
Originally Posted by salvo24
I solved mine...just add an extra washer to the O2 sensor, the O2 sensor doesnt fit tightly in the bung, and the oem washer isnt snug
Hmm didnt think about that. I will take a look at that.
Originally Posted by Excelerate
I know you guys don't want to hear this, but you get what you pay for. As long as the bolts are tight it won't contribute to noise. Now there are some guys, like Kris, that don't have resonance, but just about every other person I see posting on this site has resonance with their XS Power headers. For $100-$150 you're going to have to live with some unwanted noises. It's a crazy price for a great mod but it's not possible to have Ferrari quality with Kia pricing.
I had resonance at first, but I found that when I removed the hanger by the y-pipe, the resonance went away. I had a new hanger welded on a couple inches away from the original, and that has fixed the resonance ~95%. Don't really have much resonance at all now. I'd try disconnecting the hanger, if that takes care of the resonance, then have a new hanger welded at a different location. By doing so, it changes the natural frequency of the system and hopefully will get rid of or reduce the resonance.
Former Sponsor
Although I generally agree with you, people have paid upwards of $400 on Megan, Stone, and DC Sports headers which in some cases have led to resonance.
i took the heat shield off cause it was rattling. but im havin a rediculous amount of raspy noise. when i rev my car when its in park, it acctually sounds like i have a blow off valve. i prolly should retighten all my bolts cause i may have a leak
Raspy and BOV don't really jive as the same sound. I've always noticed that with aftermarket headers there is a bit more of a "whooosh" sound but there shouldn't be an resonance or sounds of a raspy nature.
HMM I still have this resonance that I need to get rid of. I've taken off the heat shield above the cat and still no luck. I guess I need to loosen everything and reinstall the headers. I will also get Salvo help me with that 02 sensor washer.
ive had my xs headers for about 4 years now tho i paid ~250$ for them when they first came out.. theyve always had a hiss/ turbo sucking noise.. they were on my 99 3.0 cl first then my 02 tl-s. same sound.. tho mine isnt as loud as some of you guys make it sound i can barley hear it with the window open.. and try re-tapping your o2 bung.. i did that to mine when i replaced my o2 sensor (bung was pretty badly x threaded.) and the new o2 sensor went right in and tightned up. the obx headers back in the day had the same problem. good luck pimps.
Originally Posted by dnd2984
I just removed the rubber support thing and no more resonance.
When I first put my XS on I had a little resonance I think it was do to the fact that the flange holes on the header don't meet up real well with the stock exhaust after bolting it together it was putting tension on the header. So I drilled the flange holes out ( made them wider) and used bigger washers and my resonance went away.
Jul 16, 2017 07:33 AM
CL-S progression 01
Jan 26, 2016 04:15 PM
2G-TL-Type-S-03
Sep 20, 2015 12:48 AM
