wiring issues
Old Aug 23, 2022 | 12:51 AM
Keith johnson's Avatar
wiring issues
can anyone help regarding regarding 02 TL swap to 02 TL type S motor missing plugs for outer Throttle body and how to wire up those two plugs
Old Aug 23, 2022 | 12:22 PM
Karanx7's Avatar
Unregistered Member
Just toss the VSA throttle body.
Old Aug 23, 2022 | 02:06 PM
Just curious, if he is using the type-s ECU would it not always show a VSA light (only if he has a type-s cluster) since the ECU is checking for the VSA TB via the VSA unit?
It seems like he needs the type-s engine harness if he swapped the J32A2 to his TL-P?
He also should not have the J32A2 IMRC connector if the TL-P engine harness is still in place, as well.
I wonder if he took the type-s bypass valve control unit?
@Keith johnson
So many questions, lol!
Originally Posted by Keith johnson
so i have the type S harness and ECU do i have to get the keys re programed to the ecu?
Old Aug 23, 2022 | 03:53 PM
Karanx7's Avatar
Unregistered Member
If he has the Type-S ECU and cluster, then he will have issues with the VSA light unless he also swapped the ABS/TCS module for a Type-S ABS/VSA module. He'd also have to swap to a VSA type ABS pump, and potentially different brake lines. For the IMRC connector, he could source a IMRC controller from a Type-S too. He would then need all the Type-S dash and engine harnesses.
Or just use his original TL-P ECU and throw out the VSA throttle body.
Old Aug 23, 2022 | 09:57 PM
thanks for quick reply karanx7, question would tossing the throttle body give me a check engine light, also would it affect the performance of the engine, also i am using the Type S harness and ECU
Old Aug 24, 2022 | 03:12 PM
Karanx7's Avatar
Unregistered Member
Answers to those questions are found in the reply above.
Allen_442
Sep 8, 2015 06:01 PM
Oakroadsteve
19
Apr 8, 2012 01:47 AM
0ACURATL3
Dec 16, 2010 08:29 AM
AARONSredTYPE-S
Apr 13, 2008 12:47 AM
tpeek
Feb 26, 2006 05:15 PM
