Weird thump when starting the car
Old Oct 23, 2003 | 06:12 PM
sc354's Avatar
Whenever I start the car, I get this weird thump. It's right after the starter stops turning, and the engine starts up. It only happens right at the point of starting up, and doesn't occur when I'm driving. Does anyone else have this? I find that the car doesn't start up very smoothly?
anyone?
Old Oct 23, 2003 | 06:17 PM
AcuraTL's Avatar
OG
Could be a bad engine mount.
Old Oct 23, 2003 | 06:34 PM
bug230's Avatar
mushroom mushroom
does it only happen once...If so I belive it is normal. I have had that for a while.
Old Oct 23, 2003 | 07:51 PM
sc354's Avatar
yah it only happens once. More noticeable when the engine is cold.
this is normal???
Old Oct 23, 2003 | 08:16 PM
I have the same problem. Just when its cold. I have an 02 TLS with 70K on it and it has done it since I got the car. I was gonna ask the dealer what it was when I take it back to have them look into my transmission, which seems to have a mind of its own....
Old Oct 23, 2003 | 08:45 PM
Hi there,
Got the same problem also.
If i remember well, only when the motor is cold.
Doesn't do it all the time. Could do it three days in a row.
Now a few days without doing it...
Very strange and i'm sure it is not normal, i suspect something
with the starter...
I will ask for sure on my next visit to the dealer.
If you find something let me know how it turn out.
Pierre
Old Oct 24, 2003 | 09:27 AM
VTEC11's Avatar
Yeah, my car does the same thing now that its starting to get cold?
must be normal since other people noticing this also..
Old Oct 24, 2003 | 10:30 AM
ScotTLTypeS's Avatar
Vacuum Controlled Motor Mounts ???
http://www.acura-tl.com/forum/showth...or+mount+noise
Old Oct 24, 2003 | 11:17 AM
Tx ScotTLTypeS!
Good thread reference, i will try leaving the AC off.
Old Oct 24, 2003 | 02:50 PM
sc354's Avatar
yah but here's the thing, it can't be caused by that because I always leave my A/C off. The system is going, but I have it set to A/C off. I usually run it like this during winter seeing as the A/C is not needed when it's -10 outside. So yah it's probably caused by something else in the car. Not the A/C.
Old Oct 26, 2003 | 06:59 PM
Acura A-spec
A little off the subject,but when I start my 03 A-Spec and I am pulling off for the first time,I can hear an audible groan and can feel a little feedback in the wheel.I thought it was the power steering at full lock,but it does it with the wheel straight as well.I am wondering if it might be something with the gearbox? Any ideas?
Old Oct 26, 2003 | 07:00 PM
sc354's Avatar
I think we have all concluded that this is simply the ABS doing a self test. If your ABS or VSA ever kicks in at low speeds, you will be able to hear that same noise also.
miner
3G RLX (2013+)
36
Jan 11, 2016 04:17 PM
gemz_acura
4G TL Problems & Fixes
15
Sep 26, 2015 06:12 PM
Phambam12
Sep 6, 2015 06:57 PM
jordanboi
Sep 5, 2015 01:33 AM
chrisr
5G TLX Problems & Fixes
Aug 31, 2015 08:24 PM
