Type S... is it really that big of a deal?
I was in a Pull-a-Part today and they have a couple 02 TL Type-S cars that are complete with engine/transmission. First thing I want to verify is that the transmission is the same B7WA that comes in the base model??? Second thing... If I were to swap this in to one of my CLs or TLs, I would need both the under hood harness and the under dash harness??? The last thing... Is the Type-S really so much better than the base that I really need to pull the required parts and do the swap? I have both a 2nd Gen TL Type-S and a 3rd Gen TL Type-S, but I haven't driven either of them as they both need transmissions (bought them that way). I know it's a lot of work. I wonder if it's worth it. Realize that Pull-a-Part only charges about $500 for an engine/transmission combo...
FYI the transmission is slightly different between the two, as the base model has the speed sensitive pressure regulator for the power steering. The Type-S tranny doesn't (and neither does an AV6).
I'm a little confused by your question because you talk about swapping Type-S drivetrain into base model TL, but then say you have two Type-S TLs that you're working on.
whitetiger5 (01-16-2020)
congrats on having two generations of type-s TL's AND on having a local junkyard where you can pick up a transmission for a very good price. I would research the most popular thread in the second generation forum: the AV6 swap FAQ.
https://acurazine.com/forums/second-...n-swap-905115/
This is the transmission that you want to put into your 2G type-s.
If your cars only need transmissions, why not just search for replacing that component? the engines in Honda/Acura cars hold up very well and you will more than likely not gain any benefit switching out the engine.
4th - 0.727 vs 0.653 (TL-P)
5th - 0.520 vs 0.470 (TL-P)
The AV6 has the same gear ratios as the TL-S transmission.
So, I haven't really felt the difference between the P and the Type-S yet for myself, hence the question...
Type S and H.P.
I recently bought a 2002 TL Type S, surprised how quick it is. And 26 mpg. I know if I had the 220 hp version, I would long for a Type S. But that's just me. I'm a child of the '50's and 60's, and affordability, engine less than 200 cubes, 260 horsepower and good mileage still doesn't compute. Wish I would have bought a used Acura years ago. Bought the car from next door neighbor. Acura must be bulletproof; was a daily driver for 2 of their kids while away at college, so 8 yrs. of beating on it, and it still runs good. That says a lot for Acura engineering. However...will be glad when I shrink the pile of small problems it has. Blower motor and transistor, front motor mount, working on power steering leak now and other small items; however, am enjoying, and not dreading, tinkering on cars again, and for me, that is a blessing.. Also dig all of the info. on this site, it's a big help for me. You all have a great weekend.
The following 2 users liked this post by youngjim:
Arkady (01-25-2020),
whitetiger5 (01-25-2020)
