Too much oil
Too much oil
Just a general question re. crank case capacity. Recently changed my oil with Mobil 1, container is 4.73 quarts, I seemed to add to much, eventually drained what I figured was an adequate amount, the dipstick still registers right at the upper limit dot. I can't imagine having more than 4.5 quarts in there even still...at what point is "too much" significant? Can I just pour the full 4.73 in the crankcase and call it good?
IIRC that's when the engine's completely empty, like during a rebuild, is it not? I also seem to remember seeing somewhere during an oil change w/ filter it's 4.5Qts. That's what I've been putting in mine ever since I got it......but I could be wrong.
Can anyone confirm or bust this information?
Its too cold to go get my owner manual but most of us- and on the advice of our Moderator - warm the engine first- change the oil and filter and add 4.7-5 qts
What does your dipstick say with 4.5 in it???
here is a helpful link- free owners manuals !!!!
https://techinfo.honda.com/rjanisis/...01_OMANUAL.asp
Originally Posted by acitydweller
Have you started the engine after the oil change to fill the oil filter with oil... let the engine cycle and then check your oil levels again.
Originally Posted by Rajca
fill the oil filter with oil before u start the car. u dont want any dry starts
Filling the filter before install is good practice- just for the extra margin of safety it provides in those first few seconds before it fills, pressure then builds up and oil flows thru the engine,
and the opportunity to apply a light coating of oil to the o-ring and threads is right there~
Assures excellent seal and way easier to remove next time!
If you never see FULL with 5, perhaps your betrothed would appreciate you answering one of those dipstick enlongation ads
ok chuck that does get to the oil filter- but what about the drain plug
I want to get as much old stuff out- and ofter will use Seafoam to clean the oil system when changing- so I drain it from the low point- the bolt
If using a suction pump just make sure you get 4.5 qts or so, including the .5 in the filter
Originally Posted by 01tl4tl
numerous oil threads- any name brand you like 5-W30 or 5-20 for foolhardy gen3rs
K&N- Mobil1 filters good, some use fram and have no prob, so basically buy whatever you want!
acura was looking to improve the mileage of all their vehicles to meet CAFE standards and determined you can run 20 w and not destroy the engine- is it the best weight for the engine as far as protection and lifespan- no, but it does get a tiny bit better fuel economy
Stick with 5-30 and enjoy your TL
I use 5W30 in summer and 5W20 in winter for our Canadian climate in my 03 TLS, using whatever synthetics on sale at that time (usally Mobile 1 or Penn Platinum).
Out of curiosity, I stock up several gallons when they are on sale, and is there expiry date or how long are new oils good for when kept in the garage? I figure it should be okay to store for 1 to 1 1/2 years?
Originally Posted by TwinTurbo335
sorry guys but this is kind of off topic but i saw a oil extractor at a car store. it shows that you can change your oil without crawling under the car. Can this actually be done?
vtec:
they higher number is the oils flowabilty at normal engine operating temp ~200F
unless your guage is reading below its normal summer range, what you want in cold weather is a lower cold flow number, meaning 0-20 or 0-30
The engine needs its normal protection at temp
vtec:
Originally Posted by vtec260
I've been having tough time finding synthetics with 0-20 or 0-30's at my local stores so 5W for me for now.
I was guessing that Canuks park outside in -50 F and want to jump in and get moving!
5w-whatever synthetic is the thing for cold as fsstmys said-
FULLY synthetic being the best option
Me- I live where 32F is freezing
IBankMouse
Jun 13, 2020 12:53 PM
