Taillight Problems
Old May 22, 2014 | 02:06 PM
VladkaR's Avatar
Exclamation Taillight Problems
Okay, so im new here and to get started i'd like to ask you if any of you had any problems with your taillights? If i press the brake they light up and then blinkers and hazards work. But they dont light up if i turn my lights on. Is it a fuse?
Old May 22, 2014 | 03:11 PM
teggyturnedtl's Avatar
Sounds like you may have the wrong bulbs make sure your rear bulbs are as follows rear signal 7440 rear bulbs 7443.
Old May 22, 2014 | 04:43 PM
VladkaR's Avatar
Im gonna check, thanks for the tip
Old May 22, 2014 | 04:59 PM
VladkaR's Avatar
They light bulbs are as the ones you said
Old May 22, 2014 | 05:18 PM
3.2TLc's Avatar
If ya have the correct size bulbs, make sure that they are properly installed and that the wiring is ok.
What happens if ya get in the car .....and activate the 4 way emergency safety flashers ?
Did this problem just start out of the blue or have ya done some recent work ?
It appears as though your parking and brake lamps are both non-functional, right ?
How's the front parking lamps ? Do any of the turn signals work normally at all ?
Old May 22, 2014 | 08:06 PM
VladkaR's Avatar
I bought this car off a person, and they never worked. Everything works in the taillights, BUT they dont just turn on. I press the brake and they light up, same with hazards. They work, but they dont just light up when i turn the lights on. My headlights are all fine and everything works.
Old May 22, 2014 | 09:00 PM
Ouch that really sucks. Well hopefully others will chime in but for now, if I understand you correctly your saying that when you apply the brakes your rear lights turn on. if you turn on your turn signal they work. It's only when you put your headlights in the on position that the whole rear does not light up. If that's about right my next place to look would be your multifunction switch where you turn on your headlights. You may be able to track down wether it's sending lighting to the rear or I'm not sure about this but maybe there is a separate relay? For the rear that may not be working. Before you do that tho be patient there are guys in here that can tear this car apart with there eyes closed and I'm sure they have the answer. sorry I couldn't help
Old May 23, 2014 | 06:48 AM
3.2TLc's Avatar
Lightbulb Parking lamps not working.....
Do the front parking lamps come on when ya turn the lights on ?
Check to see if the stalk switch is working properly if the front parking lamps don't come on with the switch turned on. Otherwise try a new set of bulbs in the rear.
Old May 23, 2014 | 10:46 AM
VladkaR's Avatar
Thanks for letting me know. And thats exactly what i meant. I'll keep looking. It just sucks. I need my car before summer starts due to work-.-
Mike Pilipenko
Mar 26, 2024 09:21 PM
SidhuSaaB
May 30, 2020 12:40 AM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
MikeJM310
Sep 24, 2015 07:24 PM
