Switching to synthetic...do I need to flush?
Subscribe
Sep 24, 2003 | 03:07 AM
i'm almost at 30,000 km and a change is due. the cars always been on conventional from the 1st 2 free servicing and the semi-major type 3 servicing. would be ok to just dump in the synthetic or would i need to flush out the old oil with something???
Reply 0
Sep 24, 2003 | 07:10 AM
Re: Switching to synthetic...do I need to flush?
Quote:
No flush needed. In fact, you can mix regular and synthetic 50/50 if you want,. they are fully compatable,
Reply 0
Sep 24, 2003 | 01:30 PM
It's recommended that u do an oil change w/ oil flush additive b4 u switch to full synthetic. Some conventional oils r not compatible w/ synthetic oil causing ur seals to break n leak.
Reply 0
Sep 24, 2003 | 01:39 PM
Re: Re: Switching to synthetic...do I need to flush?
Quote:
You trying to blow dudes engine up??? GOD I hope your not a mechanic
[QUOTE]Originally posted by jmai It's recommended that u do an oil change w/ oil flush additive b4 u switch to full synthetic. Some conventional oils r not compatible w/ synthetic oil causing ur seals to break n leak.[/QUOTE ]
this is the guy I'd take my car to
Reply 0
Sep 24, 2003 | 03:17 PM
well the conventional oil that's always been in my engine has been whatever the dealer uses. any suggestions on what good oil flush additives out there i could try? and how would the application work? this would be added along with the new synthetic oil?
Reply 0
Sep 24, 2003 | 03:49 PM
russianDude is right. flushing is for special circumstances or for idiots who dont have a clue
Reply 0
Sep 24, 2003 | 03:54 PM
Re: Re: Re: Switching to synthetic...do I need to flush?
Quote:
It's time for you to do some readings on modern synthetic oils.
This is a good place to begin your education:
www.mobil1.com (FAQ section):
Q:
Do I need to flush my engine before converting to Mobil 1 with SuperSyn™?
A:
No. There is no special preparation necessary when converting from conventional oil to Mobil 1 with SuperSyn™. In fact, Mobil 1 with SuperSyn™ is compatible with conventional oil should it be necessary to mix the two. However, diluting it with conventional oil will reduce the superior performance characteristics of Mobil 1 with SuperSyn™.
Back in the days synehtic oils were not fully compatable, thats why people have this myths about "engine flush"
Reply 0
Sep 24, 2003 | 04:38 PM
Re: Re: Re: Re: Switching to synthetic...do I need to flush?
Q:
A:
Reply 0
Sep 24, 2003 | 04:44 PM
no you do not have to flush your engine to use synthetic oil
Reply 0
Sep 24, 2003 | 05:55 PM
thx for all the interesting answers all. i was gonna use M1 so guess i got my answer.
Reply 0
Subscribe
