Shiftgate 1><2?
Old Nov 1, 2003 | 12:09 PM
SeCsTaC's Avatar
styling on you
Shiftgate 1><2?
What are the 1><2 or was it 1<>2 on our TLs. What does it do? Its the one below D3 i believe.
Old Nov 1, 2003 | 01:28 PM
jbx35's Avatar
That would be 1st gear to the left and 2nd gear to the right, D3 is up one and so on. When you are shifting this way it's called gate shifting.
Old Nov 1, 2003 | 04:02 PM
SeCsTaC's Avatar
styling on you
ohh ok thx alot
Old Nov 1, 2003 | 05:18 PM
Allout's Avatar
Blown is Best
Also note that if you start out with the gate in 2, your car will be sluggish because it will be in 2nd gear (not 1st gear from a dead stop). From a dead stop, 1,3,4,5th gate will start you out in 1st gear.
Old Nov 1, 2003 | 11:38 PM
SeCsTaC's Avatar
styling on you
one more thing, is gateshifting better than sport shifting?
Old Nov 2, 2003 | 10:10 AM
jbx35's Avatar
only if you're racing cause you can hold 1st gear longer. I've noticed that when I shift from 2nd to 3rd through the gate the shift is quicker. With SS, when I shift up, there is slight delay before it shifts.
Old Nov 2, 2003 | 10:14 AM
sc354's Avatar
actually I find more the opposite, I find that when gate shifting, I have to shift somewhere around 6900-7k RPM or else I bounce off the rev limiter, thus losing a **** load of time. In SS mode, it pretty much shifts instantly, give or take like 0.2 seconds.
Old Nov 2, 2003 | 01:36 PM
SeCsTaC's Avatar
styling on you
With gateshifting or SS do you have to let off the gas for a sec to shift? or do u just keep on it and shift.
Old Nov 2, 2003 | 04:04 PM
sc354's Avatar
just keep on it and shift, but keep in mind that if you're flooring it, and almost at the redline, you must shift early in order to not bounce off the rev limiter.
later
Old Nov 2, 2003 | 06:16 PM
samkws's Avatar
Comptech Freak
don't put at 2nd to start, coz it starts at 2nd gear!!!
honda puts 2nd gear as the winter purpose~
SS is better if u know when to shift...around 6800rpm...
It's Clutch
2G TL Photograph Gallery
69
Jan 24, 2010 06:07 PM
TL.00.3.2
May 23, 2009 10:35 AM
BlackuraTL
May 12, 2009 10:35 PM
pretty_ricky302
1G TL (1996-1998)
Aug 30, 2008 11:12 PM
RL_Cruizin
Mar 26, 2006 10:47 PM
