seafoamed the 'ol TL
Old 03-14-2007, 03:57 PM
  #241
01tl4tl's Avatar
Received 1,137 Likes on 1,067 Posts
Go back thru this thread from the beginning and see the many pics with circles and arrows and description of the pic
Old 03-15-2007, 10:35 AM
  #242
dnd2984's Avatar
Man it was some scary shit. I feed the seafoam, the first time my engine stalled out. So I turned the car back on. The second time it drank it all. Then I turned the car off, BUT the engine was still on? Why is that? IT sputtered then off. Turned it back on 10 mins later and shit load of smoke. I think I will be sea foaming again tommorow, I didnt feel that much of a differ.
Old 03-15-2007, 10:36 AM
  #243
dnd2984's Avatar
^ also I had the dealer do the induction service at 60k. Do they use sea foam also and charged my 79.95
Old 03-15-2007, 11:23 AM
  #244
01tl4tl's Avatar
Pretty much- yep
Seafoam is the main product used by the fuel injection service machine
Engine runon is indicative of carbon loading
Use a little throttle as you add the seafoam to prevent stalling and let it sit 15 minutes
before you restart- then a good 20 minute freeway blast at 4000 rpm
Make sure to add some to the gas tank too, that cleans out the entire injection lines and spray nozzles- very important
Old 03-15-2007, 09:41 PM
  #245
dnd2984's Avatar
Originally Posted by 01tl4tl
Pretty much- yep
So I did it again today. It sucked down a 1/2 can without stalling. I turned the car off and let it sit for 15 mins. I tried turning it on and it wouldnt. I tried couple more times and then It turned on. HOLY SHIT I have never seen so much smoke!!!
Old 03-26-2007, 02:38 PM
  #246
cjde2006's Avatar
question and sorry if it is a dumb one. Based on the photos of the vaccuum line I use to suck the seafoam up.....what end do I use? The end that connect by the PCV valve or the other end? Thanks all!
Old 03-26-2007, 03:18 PM
  #247
01tl4tl's Avatar
The end that comes from the back of the engine- across and over to the driver side, inner fenderwell area.
Where is goes to that plastic thing with another hose coming off of it, you are there.
The VACUUM part of all this comes from the engine pulling air thru that hose into the intake manifold. This is a small amount of the total vac created by the engine, but plenty to suck fluid from a can. Set the can on top of the ATF filler plug, then tilt as needed when almost empty.
Old 03-26-2007, 04:49 PM
  #248
kevin0171's Avatar
mine is around 80k km, do i need to do a seafoam?
Old 03-26-2007, 07:54 PM
  #249
01tl4tl's Avatar
Acura NOW says that new cars should have the fuel injector cleaning service every
15 thousand miles
That promotes clean burning engines and improved economy to the operator.
So a can or 2 of seafoam now, and then again every year is a cheap investment.
I bug my neighbors to do their cars too!
Old 03-26-2007, 09:28 PM
  #250
kevin0171's Avatar
sorry for my stupid, just want to make it clear before i do this
so, 3 questions here
1. I need to pull out the hose, which the red arrow points to, right?
2. then, should I use that hose to vacuum the seafoam? or do i need get another hose to connect with another end (engine side), and vacuum the seafoam?
3. I saw there is a similar hose close to PCV hose, what is that?
thanks
Old 03-26-2007, 11:07 PM
  #251
01tl4tl's Avatar
Follow the hose from the center rear of engine- thats the one you are going to disconnect and use. When you remove it from its clips, its long enough to reach into the can as described above. You cannot go wrong if you simply look under the hood
Old 03-27-2007, 08:37 AM
  #252
kevin0171's Avatar
one more question,
1. which order i should follow, oil tank -> engine oil -> PCV ? or some other order?
2. When i pull out the PCV hose, should I leave the engine on or off?
wow, seems ask too many questions here, thank s
Old 03-27-2007, 11:16 AM
  #253
cjde2006's Avatar
just bought 2 cans....1 for the intake and 1/2 for crankcase 1/2 for fuel tank. Cant wait to try it
Old 03-27-2007, 11:41 AM
  #254
01tl4tl's Avatar
Please go back to the start of this thread and read through the post
Every question has been asked and answered dozens of times
Pics and tips on each part
Do a little research
Old 03-27-2007, 04:56 PM
  #255
Wish
t7n7's Avatar
Originally Posted by kevin0171
one more question,
hey kevin, ur on my msn rite? .. i'll tell u.. in fact.. we'll meet up sometime and i'll show u how its done in person.. VERY SIMPLE.. after u do it the first time, u get the hand of it.
plus i want to see ur TL... and share mods.
Old 03-27-2007, 05:59 PM
  #256
fsttyms1's Avatar
Received 3,063 Likes on 2,119 Posts
one more question,
1. No order needed. just add them any way you want
2. running! other wise it wont be able to suck the fluid into the motor
Id use 3. 1 for each
Old 03-27-2007, 10:46 PM
  #257
kevin0171's Avatar
thanks man, if we can meet sometime, that's a very good idea
(i did msn you many times, but your status were always busy or away...)
Old 03-27-2007, 10:50 PM
  #258
kevin0171's Avatar
thanks so much, for the second question, maybe you mis-understand lol...
i mean before i pull out the PCV hose(before suck the seafoam), should i run the engine first, then pull out the PCV, then suck the seafoam.
Or just turn off the engine, pull out the PCV hose, then turn on the engine, then suck the seafoam.
thanks
Old 03-27-2007, 10:54 PM
  #259
kevin0171's Avatar
and you know what, i did call woodbine acura for that oem kit, but they told me they dont have.... is there any connection you have over there to help you order or what?
Old 03-27-2007, 11:03 PM
  #260
01tl4tl's Avatar
kevin
Yes you got it right
Engine off to remove VAC line and then remove it from its clips so it will be long enough to reach the can when set on ATF filler bolt
Start engine and dip and remove the tube to prevent stalling- car runs on gas not solvent
Use thumb on other hand to push throttle to keep engine running
IMPORTANT Engine needs to be warm to help dissolve stuff so a 5 or 10 minute drive to warm everything should be done first, then the treatment
Turn off engine after can empty, put hose back in clips and make sure if end needs to be trimmed for tight fit on plastic port.
Do some other maitenance for 15 to 30 minutes and then restart- be prepared for smoke from solvent burnoff
Freeway run at 4000 rpm and use vtec several times to really heat up the loose stuff and process it through
Normal for CEL check engine to come on and will clear itself
Try to do at a time when smoke trail will not hamper traffic- like at night on backroad
Change the oil and filter right away after adding to crankcase thru oil filler cap.
Meaning dont drive 500 miles- drive none, just idle for 5-10 minutes or under 50 miles and change- because it removes huge amounts of stuff and puts it in the oil.
Have fun and get your neighbors and friends to use it too
Old 03-28-2007, 10:17 AM
  #261
kevin0171's Avatar
kevin
WOW,thanks so much man, now i got it very clear and specific.
thanks guys, probably I'll make a video when i seafoam...haha
Old 04-02-2007, 08:44 AM
  #262
JRA2000TL's Avatar
After reading this, I decided to do mine as well. I had to remove the motor mount sensor from the bracket to get a good hold of the vacuum line and remove it. I did the intake and the gas, but I'll wait and do the crankcase right before an oil change soon.
I did get the white smoke in a nice little plume, but nothing like on that video. It did seem to make a little improvement, but I try to always use Chevron 93 fuel and Lucas fuel treatment and Mobil 1 oil...so I'm sure mine wasn't as gunky as some. Good stuff though...I love this forum!
Old 04-02-2007, 04:52 PM
  #263
MUCH bigger than you!!
Eisenhulk's Avatar
I did mine this afternoon on my lunch break. Used the whole can through the vac. line....let it sit for 30 mins, then ran the hell out of it.....Talk about a lot of smoke!! WOW!
Question: Is the amount of smoke you see an indication of the amount of carbon buildup in your engine???
Old 04-02-2007, 05:54 PM
  #264
01tl4tl's Avatar
Its more an indicator of how much solvent is in the system- thats most of the smoke trail at the start- then the hot freeway run gets rid of the carbon
Make sure to run some in the fuel to clean all the injectors and further clean the valves
Old 04-02-2007, 06:20 PM
  #265
Eisenhulk's Avatar
Gotcha. I bought a second can today....I'm sitting just above 1/2 tank....I think I may wait until it's closer to empty so the Seafoam is more concentrated.
Old 04-04-2007, 09:09 PM
  #266
6th Gear
spn_08's Avatar
So my friend has a 1990 camry with 250,000 miles, should he try seafoam?
Old 04-04-2007, 09:25 PM
  #267
dnd2984's Avatar
Yea a shit load of seafoam. Its really great stuff.
Old 04-04-2007, 10:02 PM
  #268
01tl4tl's Avatar
Ehulk
Toss the rest of the can contents in the tank
You want a slightly diluted effect so it does a longer term scrub of the injectors
1/2 tank is a great place to do that from
Old 04-04-2007, 10:47 PM
  #269
Eisenhulk's Avatar
Right on....Dumping the other can in tomorrow morning on my way to work.
Ehulk
Old 04-09-2007, 09:38 PM
  #270
01tl4tl's Avatar
I was reading the fine print on the Seafoam can about REALLY cleaning the injectors via the fuel tank method.
Standard cleaning dose is 1 Ounce per Gallon of fuel, so thats 1 pint can to 8 gallons or 1/2 tank of gas. It says use more for more cleaning, less for less.
So I put a cans worth into the 1/4 tank I had and am running that thru now.
Posting this because the directions most of us use say 1/3 can- and other members are using 1 can in a tank. So fear not, it's approved.
autozone has it on sale for 5.98, never hurts to run it in the fuel and keep everything clean, and do a super blast clean as needed.
Gas is 3.50 a gallon here and no sign of dropping. Clean systems get better mileage.
Old 04-09-2007, 09:54 PM
  #271
08 Civic SI
orgnlprankster7's Avatar
1 can in the tank is what i use works like a charm
Old 04-09-2007, 09:57 PM
  #272
01tl4tl's Avatar
Right- I was saying that 1 can in 1/4 tank puts it at super strength cleaning mode and would compliment the vac tube service method well, 1 can in each and its on sale!!
Old 04-09-2007, 10:23 PM
  #273
08 Civic SI
last time i bought 3 cans. 1 in da crank 1 in da vac tube one in the tank, at about 1/3 full. i love seafoam! the autozone near me always has it on sale for like 3.50
Old 04-14-2007, 11:04 AM
  #274
MPX
MPX's Avatar
In all honesty I'm pretty newb when it comes to cars, especially my own. The only thing I've done is take apart my center console to get a coin stuck behind the coin holder. :\
I have a 99TL with 105K miles on it, I could definitely use it. Would a mechanic be able to do this for me? Or should I grow a pair and try to do this myself?
[edit]
Is there a DIY with pictures by any chance?
Old 04-14-2007, 01:13 PM
  #275
lostkhan's Avatar
Originally Posted by sbuswell
so far it worked well on my TL and very well on my wifes 98 corolla w/155k on it. this stuff is for real.
You had questions like If you have to change the SPark plugs, the 02 sensors and change oil after 1500 miles?
IS THAT ALL CORRECT??
did you do that?
Old 04-14-2007, 03:10 PM
  #276
SOLD: 03 SSM CLS Auto
gaping46and2's Avatar
[edit]
Read through this thread. I suppose a mechanic would be capable of pouring seafoam into your gas tank and crank case, though I'd think it would be much cheaper to do that yourself.
Old 04-14-2007, 03:18 PM
  #277
08 Civic SI
[edit]
if you can pump your own gas you can use seafoam
Old 04-16-2007, 12:25 AM
  #278
01tl4tl's Avatar
MPX
This is the DIY forum for seafoam- go back to page 1 and start reading and looking at pics
About page 8 there are some good extra tips as well.
Old 04-16-2007, 09:48 PM
  #279
kman03tl's Avatar
wow tons of info when it comes time to change oil and plugs im def gonna seafoam. thanks
Old 04-16-2007, 09:58 PM
  #280
Inspired
00 acura tl's Avatar
Originally Posted by Bambo2888
amen
x2
Quick Reply: seafoamed the 'ol TL
