RT Cat + header question
Old Jan 27, 2008 | 09:47 AM
sbuswell's Avatar
I need 2 more gears
I recently purchased a RT Cat and was wondering if any fellow members that have one have had their CEL illuminate after they installed theirs. I haven't received or installed mine yet, but was curious to find out in advance. If your CEL did come on what did you do to fix the problem.
Secondly I believe my headers are leaking on the rear bank. Reason I say this is their is a small amount of resonance at 2200-2350rpm and when I seafoam the car I see a small amount of smoke coming from the rear bank. I also notice a noxious smell when I first start my car in the morning. The smell goes away after the car is warmed up though. Any idea or solutions to resolve this problem would be appreciated.
Old Jan 27, 2008 | 11:12 AM
fsttyms1's Avatar
You shouldnt get a cel for installing the RT cat. You will need to extend the rear o2 wire though.
As for the possible leak, you need to see if its from the manifold or the Y. I would double check that every thing is tight and that the gasket is ok.
Old Jan 27, 2008 | 01:08 PM
sbuswell's Avatar
I need 2 more gears
How tight should I be torqueing the bolts on the manifold, downpipe and y-pipe?
Old Jan 27, 2008 | 03:05 PM
sbuswell's Avatar
I need 2 more gears
another question. Does all air that comes into the cabin get cycled through the cabin filter before it enters the cabin?
Old Jan 27, 2008 | 08:27 PM
Hockeyman's Avatar
slobalt defender
i never through a code for my RT cat with DC headers and custom exhaust.
Old Jan 28, 2008 | 12:35 AM
01tl4tl's Avatar
no the filter does not see all the air that enters the car
There are openings in the firewall where wires and cables and brake pedal and steering pass thru.
Always retighten hot bolts after a few days and again after 500 miles.
try the kragen.com for torque specs. The size of the bolt should give a basic idea of how tight it will stand
Old Jan 28, 2008 | 10:05 PM
joseph_99tl's Avatar
i have xs headers and rt cat and apexi ws2 catback.
everything is tight and running very well...no leaks or smells.
i have had a cel on the front 02 sensor(thats the code) ever since i installed the rt cat.
i replaced the first sensor with a bosch from Advance auto parts.
it lasted long enough to get thru inspection, about 2 weeks,
i have an OEM sensor in my toolbox to install.
maybe OEM is better....i dont know..but i've driving around with the cel for about year.
Old Jan 29, 2008 | 12:36 PM
Excelerate's Avatar
Former Sponsor
The RT cat should not throw a CEL. However, if it did it would be for "Cat efficiency beyond or below threshold" which means the cat is much more free flowing than the OE cat and the ECU thinks it's b/c there isn't enough of the cat internals left to do the job properly. All you would need in that case is a defouler and they can be made for $5 or bought for $10.
Old Jan 29, 2008 | 01:45 PM
"All you would need in that case is a defouler and they can be made for $5 or bought for $10."
where can i find one of these?
Old Jan 29, 2008 | 02:25 PM
fsttyms1's Avatar
Just about any parts store
Old Jan 29, 2008 | 07:22 PM
sbuswell's Avatar
I need 2 more gears
thanks for the advice. I got the RT Cat today and it's a nice looking mod for a Cat. I can't wait to put it on. Thanks Excelerate for the fast shipping!!
Old Jan 29, 2008 | 08:08 PM
death's Avatar
I have the RT cat and have had no cell warnings. A word to the wise keep your stock cat around just in case you decide to put your car back to stock. They are not cheap to replace
Old Jan 29, 2008 | 09:27 PM
sbuswell's Avatar
I need 2 more gears
OH I will definitely be keeping the old one.
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
navtool.com
Sep 25, 2015 05:15 PM
mellsonnj
Sep 24, 2015 04:42 PM
