Painting engine cover?
Not really. I used a can and a half of 11oz. If you want try something really cool, use Duplicolor Metalcast. It comes with a base and top coat color of your choice. I used it for mine and it matched my blue AEM CAI almost perfectly. I got it at Autozone, but you can probably find it in alot of places.
Originally Posted by AcuraTl203
dave how did u mask the lattering on the engine cover? taped it the cut with a knife? or is there an easier way?
Important Question
i repainted my engine cover a while back, (with caliper paint) but the front piece where the "A" 3.2 Vtec is written is still intact because i'm unsure of how to paint it without painting the "A" 3.2 vtec. How's it done?
Get it done by a body shop. Or if you have an airblower use that. It looks a lot better than spray paint. I did mine 3 times with spray paint and didn't like how it looked so just took it to a body shop for 20 bucks.
so primer it....let it set....and than spray it with the color you want? sounds like a 3hr job or so......would a layer of clear coat enhance the luster of the color or would it jus burn off?
Then take a 3m scuff pad, scuff the th whole thing down. clean it with water. then primer, then paint. clear coat will only work on paint thats designed for clear. (if your using a gloss finish paint dont clear coat it)
Originally Posted by fsttyms1
wash the cover with dawn and rinse and dry.
what happens if you do clear it?
DAVERUBINO, Thanks a lot man...I used only one 11 oz. can...since i dont own a car. And this was my dads...i gatta show him lata or the next 3000 miles he drives he will find out.
btw here it is! https://acurazine.com/forums/showthread.php?p=1114632#post1114632
sry for the bad link....here it is: click here
sockr1
Oct 1, 2015 01:31 AM
wusty23jd
Sep 24, 2015 11:41 AM
