Optima Red Top covering
Need an OEM lip kit on my
Crappy battery died today so I decided to replace it under warranty with an Optima Red Top.
Does anyone know how to fit the plastic covering on this battery in our car (or does it not fit). It looks so clean when the posts are covered and matches my engine cover nicely. I won't be needing the battery tie down anymore right?
this is what the dremel is for~ minor adjustments to the fit
ALWAYS have a tie down system on the battery-one that will hold it secure when you pull on the battery to test
For day to day driving concerns, its better not to have the battery slapping around- damage to internal parts of battery from that will shorten its life
In a worst case scenario (what we have to plan for at racetrack/building race cars, so thats my standard) :
With a regular crash-- or worse, a rollover, if the POS battery terminal touches any metal- like the now crumpled and smashed hood --it charges the car electrically
ELECTROCUTION HAZARD to rescue persons and to vehicle occupants trying to get out
Plus some wire damage and blown main relays (hopefully they blew and saved the rest) if the car is repairable...
Thats why the pos terminal has a rubber cap over it- make sure that cap is secure, I use a plastic wire tie so it stays there--safety pays off
As always...Thank you for your extremely technical answer. You always give more than was asked for....and I love it.
Looks like im going to have to shorten the battery tie down bolts, they are extremely long
I was talking about the red covering that comes on the battery when you first buy it, but I then realized it goes on the bottom to boost the height of the battery inside the box. I still need to buy the OEM cover...but the Red Top looks nice so maybe I wont.
Is there anything to cover the posts that looks a little cleaner?
x how ever many have already said it needs a little trimming, it be on the back of the cover, so you won't see it anyways, and most aftermarket batteries need a little trimming of the cover anyways, so no worries about having to be different
and btw tin snips work better then a dremal for that sort of thing, much faster
I want to get the redtop for the TL-S but im cool off the $130 price tag. If I need a new battery tho im deff going back to an optima red/yellow top
+1 on the tin snips. I used the dremal to cut out the lexan for my fogs and yeah! that took me a good hour or three lol to get it right
not everyone owns tin snips- or even knows what they are
I understand some of us have left, right, and center cut style~ and rivet guns and tap/dies...and never ending snap-on payments
BUT
Who are you to deny a man the use of his Power Tools!?! <g>
note: I say use scissors not dremel to cut the cabin filter cover off, so even I have moderation
Tip:
to make a nice cut on over-length bolts--remove bolt- put 2 nuts on it, the 2nd ending where you want to cut
Make cut with hacksaw or,,you guessed it- the power tool!!
Now remove the 2 nuts- they will smooth the thread end as they come off, work it back and forth a few times as you remove
Now you have a perfect size bolt
Use 2 nuts -locked against each other- to install hold down (one wrench holds bottem nut tight- another wrench tightens against the first)
As I described before,, its important the battery not move or have the hold down come loose- 2 nuts counter-strained to each other and that setup is going nowhere
Note: leave the cover off the battery for improved cooling to batt- actually heat removal-dispersant,,, improves lifespan of battery when cooler
Get those rubber caps for the cable ends- covers terminals safely and cleanly.
Parts store has them for a few dollars a set
I know I get wordy but am trying to share a lifes worth of experience in the biz and around cars boats bikes and airplanes
Try to make certain there is no doubt on instructions or procedure for diy or diagnostics
BUT
Tip:
oh that cover, yea i put it under neath it to make it more taller so the tiedown isnt cranked all the way.
BUT
Tip:
BUT
Tip:
and even at home too
mada51589
Jan 9, 2025 04:40 PM
wusty23jd
Sep 24, 2015 11:41 AM
C2CuSn07 TL
Sep 11, 2015 06:54 PM
