O2 Simulator for high flow cat
If anyone got a high flow after market cat and gets a Check Engine Light once in a while with the code P0420, this little thing will resolved the problem. Is an O2 Simulator, I just install this on my TL and it works great.
https://www.casperselectronics.com/M...ory_Code=honda
you can also make your own.. 2 ways
spark plug non foulers (pulls sensor out of the exhause stream)
or
The concept the same except the wire colors differ. White on the CL/TL is the same as black on this pic. Green is the same as his grey. The white on his schematic are the same as the black in previous pic.
i got this info from here http://home.insightbb.com/~niedejb/
go to installs. i did this and it only costed me 4$ for all the parts. not sayin your way isnt easier which it is.. but this way saves you ~50$
or
2400 Watts in a TL...Why?
1 Post
Offtopic I know but.. I;m interested..
1990 Ford Probe GT: Custom Apex N1 exhaust, IHI Turbo upgrade boosting at 18psi, HKS intercooler, Blitz BOV, Greddy turbo timmer, Greddy Boost controll, SuperChips ECU upgrade, dry NOS setup, Ground Controll Coil Over, Suspenssion Tec. Sway bar, ACT Kevlar clutch, UD racing crank pully, Home Made intake, Home made strut bar, Random Tech Cat
What times and numbers are you getting with this little beast? 18psi and NOS... damn that must boogy?
Originally Posted by z3Ro
would that o2 sim work with a test pipe too? or is it just for highflows only...i would imagine itll work with test pipes too...
The fastest ET I got is 12.43 I remember it was at 115 or 118 mph don't remember the speed. The ford probe GT is basically a Mazda MX6 FE2T engine, compression is too low 7.5:1 to make high HP. I need to change to higher compression piston to get more HP. This might be my next project depends on my budget.
or
or
it will only send as much as its receiving.. it only uses the extra voltage for the heater circuit, which is seperate from the signal circuit. i used the diagram above to make mine and never had a problem with it. i just lost more bottom end than i gained at the top so i took off the test pipe. with the test pipe i ran a 16 flat @91 mph in the 1360. w/o test pipe 15.2@89.. i did remove all my speakers out of the trunk for the second time i went to the track. but that didnt make up for almost an entire second.
i made a capsule out of a shock sensor body. then i took hot glue and sealed up all the holes. and padded the board inside with foam from a tool box. made me feel smart for a minute.
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
