View Poll Results: What am i doing
Making a Dog Cage
6.05%
Making a Roll Cage
1.42%
Making a (not true) Dual Exhaust
11.74%
Making a rear mount turbo setup
17.08%
Just sitting back drinking beer doing nothing.
19.57%
Adding a turbo up front
7.47%
A supercharger
6.41%
The box contains 3.5 parts
6.76%
Time Machine
16.73%
3.7 Build
6.76%
Voters: 281. You may not vote on this poll
Now what am i up to
Old 08-12-2014, 07:37 AM
  #1441
fsttyms1's Avatar
Received 3,063 Likes on 2,119 Posts
Took and cut up a bumper i got from the salvage yard to fill where the license plate was and plastic welded it together.
3.2TLc (08-13-2014)
Old 08-12-2014, 04:30 PM
  #1442
03 tls nc's Avatar
fsttyms1 that looks badass!!!
How much did you mill off your heads and block, didn't you use a thinner head gasket?
Old 08-13-2014, 10:37 AM
  #1443
fsttyms1's Avatar
I cant find the piece of paper from the machine shop right now but i do know it was over the service limit. If memory serves correctly it was .060 for the block, heads were .002 and the head gasket was .027
03 tls nc (08-13-2014)
Old 08-13-2014, 06:11 PM
  #1444
3.2TLc's Avatar
The car's rear is starting to shape up and taking on a much newer updated appearance.
The lower diffuser will enhance the bumper and once the license plate's pocket is in place, it'll all come together. As of now, just a bit leary of the sharp accent sculpture lines above the plate area. Sorta has a bit too much Euro "German" look, IMO. Perhaps the new smoked tails will finish things out and make things flow.
Keep up the good work with the body mods !!!
Old 08-13-2014, 09:08 PM
  #1445
Gabru678's Avatar
Fsttyms!
I cant see the pics and I reaalllyy want to!
Edit: Im a dolt. Just click on them. Seems Photobucket wants users to buy hosting so they arent displaying pictures via thumbnails.
But yea great work as always!
Old 08-13-2014, 10:08 PM
  #1446
fsttyms1's Avatar
Hummmm thats odd.
Old 08-13-2014, 10:20 PM
  #1447
03 tls nc's Avatar
That raised your static compression about 2 points? Did you have any valve to piston clearance issue cutting that much? How much room is there to play with?
From the math I did and talking with the guys at King .040 is = to 1 point of compression. My j35a3 has 10:1 pistons and I'm using j32a2 cams, so I at least need to get back to the 10.5:1 of the j32a2 cams milling .020. It cost me $1/ .001 milled for both heads, wanting to raise compression as much as possible from milling the heads but don't want to get into timing or valve to piston issues.
Old 08-14-2014, 07:28 AM
  #1448
fsttyms1's Avatar
Found the machine shop sheet. .006 block, .002 heads, .027 head gasket.
03 tls nc (08-14-2014)
Old 08-21-2014, 09:59 AM
  #1449
fsttyms1's Avatar
Yumcha (08-21-2014)
Old 08-21-2014, 10:48 AM
  #1450
rockstar143's Avatar
Received 19,986 Likes on 14,496 Posts
you have taught me patience, sir.
Old 08-21-2014, 02:20 PM
  #1451
deal with it
dreem1er's Avatar
damn it fatty....bring on the flood of pics already...I want to see so many pics my pc freezes....
looks great btw
Old 08-21-2014, 02:22 PM
  #1452
Yumcha's Avatar
Received 22,805 Likes on 13,987 Posts
Old 08-21-2014, 05:28 PM
  #1453
3.5 psi
gnuts's Avatar
Lookin good
Old 08-21-2014, 06:25 PM
  #1454
fsttyms1's Avatar
600k miles, and very dusty and look at that reflection
Old 08-21-2014, 06:27 PM
  #1455
fsttyms1's Avatar
looks great btw
Soon..... ill post more
Originally Posted by Yumcha
Originally Posted by gnuts
Lookin good
Old 08-21-2014, 06:41 PM
  #1456
crazyasiantl's Avatar
Old 08-25-2014, 10:47 PM
  #1457
fsttyms1's Avatar
Rear fender inner door work.
Old 08-25-2014, 11:28 PM
  #1458
Skirmich's Avatar
Received 1,017 Likes on 867 Posts
That looks good Fatty! Cant wait to see it finished..
Old 08-26-2014, 02:30 AM
  #1459
fsttyms1's Avatar
Old 08-26-2014, 06:22 AM
  #1460
Fatty
People realize it's Fast Times, right? I think Spiccoli would be a more fitting nickname!
Old 08-26-2014, 07:30 AM
  #1461
fsttyms1's Avatar
Fatty
Yea I blame Twiggy for that name I should people for it
  #1462
fsttyms1's Avatar
Old 08-26-2014, 07:49 AM
  #1463
Well, kudos to being able to weld and shape metal...helluva an art.
3.2TLc (08-26-2014)
Old 08-26-2014, 07:51 AM
  #1464
Yumcha's Avatar
You'll blame me for nothing!
Old 08-26-2014, 07:57 AM
  #1465
You're not Twiggy, are you?
Old 08-26-2014, 07:26 PM
  #1466
fsttyms1's Avatar
Oh he is, the one and only.
Old 08-26-2014, 07:27 PM
  #1467
fsttyms1's Avatar
I blame you for everything. Even stunnas charts, the recent spike in broccoli liking, and even global warming!!!
Old 08-26-2014, 07:30 PM
  #1468
fsttyms1's Avatar
Old 08-27-2014, 10:26 AM
  #1469
01tl4tl's Avatar
Received 1,137 Likes on 1,067 Posts
a slight clarification on fattys name as he originally explained to me years ago = Fast Times WON
Old 08-27-2014, 10:32 AM
  #1470
This thread always delivers...
Just waiting on some finished car pictures though
Old 08-27-2014, 03:45 PM
  #1471
Skirmich's Avatar
PS: I know is Fast Times.. But his Acurazine name is Fsttyms1..
When I'm typing I do like this "F a t t y" because I miss the "S" I blame iOS too since the predictive dictionary already stored "Fatty" so even if I spell it right the auto correct still inputs "Fatty" instead of "Fstty" which still mark it red as spelled wrong hahahaha too lazy to change that out though, just gotta know I mean no bad while saying fatty.
So nope Yumcha didn't started it for me.
Old 08-27-2014, 04:12 PM
  #1472
3.5 psi
gnuts's Avatar
What do you do where the flare hits the bumper? (Because it's plastic)
Old 08-27-2014, 04:50 PM
  #1473
fsttyms1's Avatar
Cut, shape and plastic weld pieces to get the correct shape, much like the rear bumper where i cut out the license plate pocket.
Old 08-27-2014, 04:52 PM
  #1474
fsttyms1's Avatar
Oh and i started to modify and customize the rocker panel side skirts
Old 08-28-2014, 10:16 AM
  #1475
fsttyms1's Avatar
And now im laid up on the couch with my back out
Old 08-28-2014, 05:06 PM
  #1476
3.2TLc's Avatar
^^^ Lame excuse for taking extra time and being sidetracked, imo. Just getting old !!!
Cut, shape, weld and mold.......how about a chiropracter ?
Old 08-28-2014, 05:13 PM
  #1477
Yumcha's Avatar
Old 08-28-2014, 05:53 PM
  #1478
fsttyms1's Avatar
wouldnt do anything. Everything is aligned perfectly. Had x-rays, MRI, and blood work done and there is nothing showing as to why my back goes out.
Old 09-03-2014, 12:04 PM
  #1479
Yikes's Avatar
Hey fsttyms1 how many miles on the TL these days? Last I heard around a year ago it was about 600k. It has to be close to 700k right?
Old 09-03-2014, 01:10 PM
  #1480
I want more pictures. Hope your back feels better...
Quick Reply: Now what am i up to
