View Poll Results: What am i doing
Making a Dog Cage
6.05%
Making a Roll Cage
1.42%
Making a (not true) Dual Exhaust
11.74%
Making a rear mount turbo setup
17.08%
Just sitting back drinking beer doing nothing.
19.57%
Adding a turbo up front
7.47%
A supercharger
6.41%
The box contains 3.5 parts
6.76%
Time Machine
16.73%
3.7 Build
6.76%
Voters: 281. You may not vote on this poll
Now what am i up to
Old 02-11-2013, 03:50 PM
  #1001
fsttyms1's Avatar
Received 3,063 Likes on 2,119 Posts
Off to the machine shop
  #1002
Chapter Leader (Southeast Region)
Stephen00TL's Avatar
Originally Posted by fsttyms1
MDX and Type-s are the exact same. (same part number 17050-PGE-A01) The Upper intake main, lower mani, and heads are the same, even the blocks are the same as well.
Hmmm that's weird. It will still be good once you finish all that work
Old 02-11-2013, 04:00 PM
  #1003
fsttyms1's Avatar
Hopefully ill have the block back by the end of the week now that i received the block guards
Stephen00TL (02-11-2013)
Old 02-11-2013, 04:17 PM
  #1004
MilwaukeeDave's Avatar
I wish the machines at work were small enough to do side jobs but unfornately for me my machine is huge as fuck and all my hardware is huge so can't even secure a small job if I wanted to. Maybe after my shift I could go up to the tool room but even then I'd have no fixtures. Just have to open my own shop I guess.
Old 02-11-2013, 04:56 PM
  #1005
fsttyms1's Avatar
you have access to tig welders?
Old 02-11-2013, 05:42 PM
  #1006
All welders. There's hundreds. Just gotta find someone willing or pay em a little bit but usually I can get someone to do it free.
Old 02-12-2013, 09:23 AM
  #1007
fsttyms1's Avatar
hummmmmm Road trip
Old 02-12-2013, 09:42 AM
  #1008
I'm looking for the fucker right now. I got my lowers I'm working on that I just got. They had a crack that was only repaired outside so I ground it out some now I'm gonna have him fill in the crack then I'll get it looking like brand new. These older guys here wander off and can be hard to find sometimes lol.
Old 02-12-2013, 01:40 PM
  #1009
Carson-TL's Avatar
Dude.....I wan't to be you right now.
Like, how do you have the knowledge to do that! I mean we all dream but dude...ah man, I'm mad right now, like I feel like my life is worthless because I can't do any of this stuff and you just do it for fun on your weekend....damn.
A4 headlights, 6 speed (WHICH I REALLY BADLY WANT), engine parts everywhere, an awesome looking dash, then you just go ahead and buy new trunk and door panels, AND You have a Nice Malibu Boat!!!!!!???? I am freaking jealous.
Old 02-12-2013, 01:52 PM
  #1010
Here's what I got going on here. I bought these runners and from what I've been told they were ported and polished by Paul (NVA-AV6 is his name I think) the outside of the crack was welded pretty nicely but nothing inside. Though he said they don't leak, I'm not taking any chances. Here's some pics:
Here's how they came:
I ground out that weld booger and dug into the crack to make room to be filled w weld:
The polish on these is pretty good but they could use more porting. I'm gonna start on the one not cracked while I wait on my welder and just go up to the line I see from the gasket. Then I plan to hone both mating surfaces and throw them puppies on.
Old 02-13-2013, 08:53 AM
  #1011
Are you opening up the whole runners to the gasket size or just the start of them??
Old 02-13-2013, 10:45 AM
  #1012
fsttyms1's Avatar
i just do it. i dont worry about if i can do it or not, i go into it like i have done it before and just do it. Just dont be afraid to try. Its not like i had experience putting A4 headlights in before, or like i have ever rebuilt a motor before my first time i ever rebuilt one. You have to start somewhere. Plus with the advent of the internet you can literally find anything in minutes if you need help.
Old 02-13-2013, 10:52 AM
  #1013
fsttyms1's Avatar
If they are welded up on the outside they should be good. How did they get cracked? My tig welder is broke but i can aluminum rod braze them. Bring them up.
The whole thing is getting opened up. I have found the heads have the most to gain from this. There is a lot of material to remove which should allow for some serious flow and good gains.
Old 02-13-2013, 05:41 PM
  #1014
I got a guy a work says he can fit his TIG torch in there and fill it in for me. Ima go get it back tomorrow hopefully. Then I'll grind and polish it back to nice again. I can see the old gasket marks so I'm gonna open them up to that size then maybe I'll attempt the heads on a weekend off. Did u just stuff mad rags inside the heads to keep them free of chips? Hopefully this goes well. I've read not to polish to too fine of a finish or it will interfere w atomization of the fuel due to lack of turbulence in the air. True or false?
Old 02-13-2013, 07:48 PM
  #1015
fsttyms1's Avatar
My heads are off and sitting on my work bench with the valves and everything out of them. Im not sure i would do it with the heads attached. You wont have enough room to maneuver i in there to do it properly on the vehicle. Plus with them off you can open the exhaust side as well.
As for smooth or not smooth, the jury seems to be split on that. Personally i dont think it matters on modern fuel injection setups like ours as the fuel injector sits just before the head and there is no need for turbulence up in the intake or runners to mix the fuel Maybe back in the carburetor days where it dumped the fuel in before the intake.
MrMoAcuraPar (08-18-2013)
Old 02-15-2013, 11:45 AM
  #1016
For the middle of the ports are you in there w a flex hone or just a normal grinding stone?? I'm running out of tool length w my current setup.
Old 02-15-2013, 01:21 PM
  #1017
fsttyms1's Avatar
Both. Ive got all sorts of stones (i find the ball shape to work best once you get in further). Im also using port and polish kits like these
You can get a good set of these at Harbor freight for like 20 bucks
And when every thing is said and done ill use a set of these
Old 02-15-2013, 01:36 PM
  #1018
fsttyms1's Avatar
This is a good video to watch
http://www.powerblocktv.com/episodes...r-power-how-to
Old 02-15-2013, 01:42 PM
  #1019
Awesome. Thanks a ton! Here's what I got so far, started on the head side:
Old 02-15-2013, 02:09 PM
  #1020
fsttyms1's Avatar
Looks great
Old 02-15-2013, 06:21 PM
  #1021
fsttyms1's Avatar
Did a little work to the heads today. There is a pretty good lip where the valve seat meets the head that i was able to smooth out, and some pretty decent casting marks that need to come out. I wont go much smoother on the intake ports here to allow a little turbulence to help atomize the fuel. Ill just clean things up a little. When i get to the exhaust and combustion chamber side ill polish those. Ill also take a little lapping compound and clean up the valve seats and valves.
Old 02-15-2013, 06:54 PM
  #1022
Wow good job that looks great
Old 02-15-2013, 07:30 PM
  #1023
Wish it wasn't my daily so I could pull the heads and get this in depth. Or that I had money for new heads or even better type S engine!
Old 02-15-2013, 07:52 PM
  #1024
fsttyms1's Avatar
Strip them down on a friday night, take all day sat and sun to port n polish and reassemble sun evening. It can be done
Old 02-15-2013, 07:56 PM
  #1025
fsttyms1's Avatar
Machine shop called and said these have been installed and welded in, the block will be dun monday
Old 02-15-2013, 07:59 PM
  #1026
I don't have your skills w these motors plus I work most every weekend. 12 hour days this weekend too. Plus I can't occupy the garage overnight because they'll break in the van if left out so any extended job I gotta do outside and right now the weather won't allow that.
Old 02-15-2013, 08:03 PM
  #1027
Does this prevent piston/valve interference in the event of timing belt failure??
Old 02-18-2013, 10:44 AM
  #1028
fsttyms1's Avatar
No, The J Series is an open deck design motor. These take the open deck design of the J and close them (the space around the cyl walls). It gets put in to stiffen the cyl walls from "walk" slight movement which distorts the cyl.
Open deck
With block guard in place
Old 02-18-2013, 04:58 PM
  #1029
Making a very reliable motor even more reliable = winning. Dumb question, but how's that held in place? I don't see any weld.
Old 02-19-2013, 06:30 AM
  #1030
fsttyms1's Avatar
(thats not mine, its just a pic to show where it goes) It can be held in place with red loctite or a few tac welds. Its not a loose fit, its very tight.
Old 02-19-2013, 07:00 PM
  #1031
fsttyms1's Avatar
Started porting, smoothing things out and gasket matching on the Exhaust side of the head. There is a TON of material here to open and match. Now ill have to see what can be done to the headers or see if ill have to build new ones. This thing should really flow now.
Gasket matched
I want these headers. (yes those are on a J series)
Old 02-19-2013, 09:40 PM
  #1032
Looks like its coming along nicely, I think with the motor set up your going for you will need to do a custom set of headers. It will help make more power and wont be as restrictive as the basic aftermarket headers.
Old 02-20-2013, 06:44 AM
  #1033
fsttyms1's Avatar
Yea, i most likely will make a set, ill probably do that sometime in the future (this summer) Maybe head down to King motorsports and see if they will make a set
Old 02-20-2013, 08:25 AM
  #1034
Good idea I think if you didn't it would be a weak link to your new set up.
Old 02-20-2013, 10:39 AM
  #1035
fsttyms1's Avatar
I dont think it would be that bad, but i know there are gains to be had which is why i will probably make my own. (i really need to get my TIG fixed)
Old 02-20-2013, 10:50 AM
  #1036
I gotta take some time and practice my welding. Been machining so long that now I just grab a guy from the shop to weld for me. We are paid by the hour so they don't really mind, lol !
Old 02-20-2013, 02:34 PM
  #1037
fsttyms1's Avatar
You wouldnt even begin to imagine the things i would have done to the car by now If i worked at a machine shop. Seriously, take advantage of it
  #1038
fsttyms1's Avatar
Or i will
Old 02-20-2013, 02:54 PM
  #1039
Avant Garde Wheels
jjashaa's Avatar
this thread is awesome.
but still no dog cage
Stephen00TL (02-20-2013)
Old 02-20-2013, 03:33 PM
  #1040
fsttyms1's Avatar
Its because i let Maya run FREE
Quick Reply: Now what am i up to
