Need some advice regarding engine swap
Old Sep 26, 2014 | 06:35 PM
AMart83's Avatar
Hey everyone,I might be replacing my engine soon. I'm hoping you guys could give me some advice.
I'm wondering what parts do you recommend I change?
For sure:
-timing belt
-water pump
-spark plugs
But what else do you guys recommend that I change while the engine is pulled out and I can get something changed for free or at little-to-no cost?
Also, if you recommend a part, should I go with an OEM or a name brand aftermarket (for example, I'll be using the Aisin timing belt and water pump kit)?
Thanks in advance.
Old Sep 26, 2014 | 06:58 PM
Skirmich's Avatar
Things you mentioned plus:
1.- Rear Main Seal
2.- Cams and Crank Seal (3 Seals in total)
Those 4 things are usually really-really expensive to fix once the engine is installed.
Old Sep 26, 2014 | 08:20 PM
3.2TLc's Avatar
Our TL motors are very durable unless abused or neglected.
Has the present existing motor been fully checked out as to being totally trashed ?
If so, what was the diagnosis ???
Old Sep 26, 2014 | 09:33 PM
Karanx7's Avatar
Unregistered Member
I would definitely change the rear main seal, but I wouldn't worry about the cam and crank.
Also, always go with OEM with this stuff. You're expecting these parts to take up to 10 years of abuse, no reason to cheap out here.
Old Sep 27, 2014 | 11:28 AM
01tl4tl's Avatar
Im told by other ziners = the aisin kit is the exact same ie: is the maker of oe kit
use Honda thermostat ngk plugs yadayada
do the egr cleaning of intake manifold, do some dremel cleaning up of rough edges of intake ports
whatever it needs in motor/trans mounts this is the time to do it- takes minutes to install the front!
rad cleanout or replace, new hoses for rad and heater hoses- one blows and the engine is toast
isn't this the car we have been working to locate coolant loss- history of overheat and past owner attempts to fix,,recent purchase?
Old Sep 27, 2014 | 11:40 AM
01tl4tl's Avatar
I would go with all the new cam-crank seals- for the few dollars in total for the protection of not using 13 years old and may have been sitting without oil keeping them fresh- rubber seals
You have all the parts loose or removed to reach them, its like replacing the timing belt and not doing the water pump when its the very next- and last thing- there!
but private shops and even dealers will quote without the wp just to make a low price on the 105 service and get the job in the door- where the price jumps because hey you need a wp!
its sitting on an engine stand- do it now and be done with it is my motto
adjust the valves while its on the stand, new gaskets and new rubber grommets for the valve cover gasket bolts- those tend to leak anyway
Service the throttle body/IACV
clean/replace all ground wires and batt pos cable as needed- can diy new wires
for good measure- a new Denso front O2 sensor will make sure its running correctly
Old Sep 27, 2014 | 01:23 PM
Skirmich's Avatar
That's 13yr old Cams and Crank Seals..
With a dropped engine and doing the timing belt already, Why would you not do the Cam/Crank Seals with the timing belt too ??
They are up to be changed with all the mileage/years, And easy as pie to change with the engine out.
Old Sep 27, 2014 | 04:23 PM
3.2TLc's Avatar
Hey AMart83, was your present motor professionally diagnosed as being totally shot ?
If so, what were the main things wrong with it ? Overheating or what ? Was it smoking and banging ?
Old Sep 27, 2014 | 07:09 PM
01tl4tl's Avatar
ck his other threads detailing the problem and all that's been looked at
Old Sep 27, 2014 | 07:24 PM
AMart83's Avatar
Thanks for all the advice everyone. What about belts? Replace all of them or just certain ones?
I can't find an honest mechanic in Miami, so nope, I can't confirm. I'm just planning ahead for the worst case scenario.
As far as symptoms go, it misfires and sometime (every 4-7 cold starts) it will blow white smoke out the exhaust for a bit.
As you know, the mechanic who checked out my cooling system told me it was an internal leak in the engine, but the guy didn't even mention needing to burp the system even after I brought up that there was air in the system and it was burping right in front of him! He also never ran a compression test or a leakdown test to validate his diagnostic.I also forgot to mention that he took 7-10 minutes to look at the problem. I actually had to talk to him as he was walking back to his truck as he was ready to go to his next appointment. So yeah, once I find an honest mechanic, I'll have them do the leakdown test (in front of me, of course).
Old Sep 27, 2014 | 07:28 PM
Skirmich's Avatar
Unless you see something wrong with the P/S Belt you can replace it while doing the Timing Belt as it has to come off anyway.
Accessory Belt can be replaced later on.
Old Sep 28, 2014 | 08:25 PM
01tl4tl's Avatar
but why not replace all the belts and tensioners now while its easy ?
and, based on experience, the part you don't replace will be the one that bites you~
take the tension off a 12 year old belt and its tensioner loses its sense of self worth (or spring pressure etc) = failure after new belt installed, tensioner fails = total bummer
replacing parts of engine sitting on a workbench = Priceless!
Old Oct 10, 2014 | 07:09 PM
3.2TLc's Avatar
So, are ya gonna rebuild the old motor or replace it ???
Old Oct 10, 2014 | 10:37 PM
03blackbeast's Avatar
I would agree with the above. I don't know if I'd worry about can and crank seals though. I'm getting ready to do my timing belt and have been doing extensive research on it. I actually emailed Eric the car guy to see what he said about those seals. He says quote "don't worry about those unless they're leaking. But I've never actually seen one leak". That's just my 2 cents though. Really up to you. Could be cheap protection or an area where you could save a buck.
Old Oct 16, 2014 | 06:26 PM
3.2TLc's Avatar
Question ......UPDATE...... (please)
dirtyspitshine
Jan 3, 2023 08:23 PM
justin7779
Dec 25, 2015 10:33 PM
BigJilm
Sep 21, 2015 08:32 PM
02tljj
Sep 11, 2015 12:37 PM
ninersfgiantsfan
Sep 9, 2015 01:14 PM
